Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Arkansas Radio Discussion Forum
Arkansas Radio Discussion Forum Forum for discussing Radio Information in the State of Arkansas.
Old 01-14-2013, 4:31 PM
Default Little Rock Update
Does anyone have any info on the status of the Little Rock area upgrade to digital? How much longer maybe?
Old 01-14-2013, 10:32 PM
milf's Avatar
Careful, I CAN hear you!
Send a message via MSN to milf Send a message via Yahoo to milf
Initial testing and changing of equipment etc will commence with Fire Departments over the next 2 or so months, with everyone else going later. Completion in 4 to 6 months. Assuming no complications etc...
Admin & Mod for AR, LA, MS, and TN
Scanology, its the path to monitoring happiness!
Support your local Scanologists!
Old 01-23-2013, 8:37 AM
KF5EYR's Avatar
How long will it take for the RR database to be updated when the change takes effect?
Icom IC-208H Icom IC 2200H (w/D*Star)
Yaesu VX-6R
RS PRO-163
Old 01-23-2013, 1:33 PM
milf's Avatar
That depends on how fast we get the information submitted to us.
Old 01-25-2013, 12:18 PM
Do you guys know what kind of system they will upgrade to? I have a PRO-106 and am curious if it will still scan them?
I use radios that operate on this system... I hope the upgrade is worth it. Right now most the people I work with cut off their first 2 words because they don't wait after keying up. :-\
Old 01-25-2013, 1:49 PM
milf's Avatar
They are upgraqding the current Type II to P-25, and it will be part of the AWIN. At this time it is unknown if they will upgrade to Phase II TDMA or not. As far as I have heard there isn't any mention of TDMA on the AWIN at all yet. With the complaints that have been made about overloading of the AWIN in the LR area, this at least will add more towers. Then again it will also add a massive amount of users. I am very surprised they have not begun phasing in TDMA on AWIN as it will double the capacity load. Yes it also would make scanner owners unhappy to start with since buying a new TDMA capable scanner means popping out $500 more bucks.
Old 01-25-2013, 4:29 PM
KF5EYR's Avatar
I am planning on getting the Uniden BCD-996XT, or the GRE-800 if they do go to type 2 . The system change will pretty much make a brick out of my RS-163, at least as far as central Arkansas is concerned. Thought I would wait just a bit, though. Probably get the relatively new Icom ID-51A to add to my D*Star line up first. Be my luck, I'll get the Icom and they'll get the system up the same week. Hate not being able to scan public service, though. I guess I have time for a little further thought.
Yaesu VX-6R
RS PRO-163
Old 01-25-2013, 4:39 PM
weather4ar's Avatar
TDMA might be in the future, but most likely they'll just use new smart zone controllers. No need to replace the P25 system just to expand it.
weather4ar -
http://www.weather4ar.org
Old 01-26-2013, 7:49 AM
milf's Avatar
Once again, they are going full P-25 and converting ALL sites over to AWIN from the Type II. Eventually, AWIN will start doing the minor adjustments to have Phase II compliance. LR is the second system to switch over to AWIN, and there is at least one more making the switch very soon, with two others "thinking about it". FD's are getting the first "touches" so as to deal with all the possible SCBA issues etc, that are now well known and pretty easily dealt with. Then the LEA's will get their turn, then DPW etc. Total transition time factoring in new consoles, mobiles, HT's, minor, and major infrastructure work on the sites, and training, is about 6 months from now. If the economy really ever turns around and things really look up again, there are several counties that are looking at adding additiuonal AWIN sites to improve coverage etc. We will add/change info in the db as we get it. TY for your patience.
Old 01-30-2013, 10:48 PM
btritch's Avatar
Send a message via MSN to btritch
At least they can hear it, I have 3 over $500 scanners in the house and can't hear anything at all in this county and to top that am on a volunteer fire dept and still can't get the new stuff, There's a lot of unhappy folks around here, If I could buy a $500 scanner and hear them I'd be happy! Ha Ha! Also I noticed Russellville PD switched and they went encrypted which sucks, Is the LR systems going to open or are they going to be encrypted as well?
Brian
Northeast Arkansas
Old 01-30-2013, 11:41 PM
I'm just curious if all of these unhappy people are making noise to the people who need to hear it...
Mark | Arkansas
Radio Shack Pro-106 | Uniden HomePatrol-1 | Uniden BCD996XT
Thanks for being a part of the RadioReference.com Community!
Old 01-31-2013, 12:00 PM
weather4ar's Avatar
At least in Russellville, you can still hear the Fire Department and EMS in the clear. We haven't had anything in LR encrypted on their current system, or AWIN. Conway PD is the only encryption of a trunked system. Conway FD is in clear digital voice. MEMS is also in the clear.
weather4ar -
Old 02-07-2013, 8:20 PM
If Moto ops up that free ADP encryption to them, then I'm sure they will. Russellville have three police talkgroups with all three encrypted. They should turn the main dispatch encryption off and keep the other two for private stuff.
Old 02-08-2013, 1:54 PM
It may have been said already, but don't start holding your breath for TDMA on AWIN. Arkansas requested a waiver of the 700MHz narrowbanding deadline in 2016. Since the overwhelming majority of the 28K radios on the system are not TDMA capable, it's a pretty big deal even if and handful of sites use 700MHz.
Tags
arkansas, digital, little rock, p25
