Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Arkansas Radio Discussion Forum
Arkansas Radio Discussion Forum - Forum for discussing Radio Information in the State of Arkansas.
Old 01-13-2018, 4:01 PM
n6766j's Avatar
Question AHP troops
I pulled up a map of AHP troops and ASP troops. They appear identical and have the same designations. (A - I). However, the RR data shows the AHP troops labeled as numbered troops, not by letter. I the RR list complete?
I ended up loading the entire ASP listing into each county we will be traveling through while in Arkansas.
Always Ready - Always Caring - Always There
My work number is 9-1-1
Tim Robinson
Fire Dispatcher
San Diego Fire-Rescue Department
Old 01-13-2018, 6:23 PM
03msc's Avatar
Post the maps you found. I think they were showing the same. DoT districts are numbered while ASP troops are lettered. This has been discussed before in other threads and it's always confusing because ARDOT doesn't have that info published (last I looked, that is).
Mark Arkansas
Uniden Whistler Kenwood Yaesu
Old 01-14-2018, 9:03 AM
The asp and ahp troops are close but not identical.
Old 01-14-2018, 9:32 AM
03msc's Avatar
I wasn't clear in what I was trying to say. I meant to say - I think the maps you found are the same map (both showing ASP troops) as AHP districts are not the same and are numbered, not lettered. As has been discussed in the past, it doesn't seem like anyone can find a AHP districts map...or at least couldn't at that time.
Mark Arkansas
Old 01-14-2018, 9:39 AM
Here is an ahp map
Old 01-14-2018, 9:45 AM
Hope this helps
Old 01-14-2018, 11:02 AM
milf's Avatar
Careful, I CAN hear you!
Someone pleaseeeeee WIKI that, and with this and ASP map, no more confusion unless AR follows so many other states in combining dispatch centers, and planning redistricting (the last thank goodness is still just in talking stages in most places.) Because to combine AHP and ASP would be problematic in that if I recall, AHP, like MDOTE in MS, is centrally dispatched from the HQ. With ASP, like pretty much all State Police/Highway Patrol, has multiple regional dispatch centers. Also, anyone know if AR is ever adding an MAP (Motorist Assistance Patrol) system like the other states? Even MS has a limited one now from what I hear. (Nothing like LA, TN, NC, SC, IN etc,,,)
Radio Shack: PRO-92, PRO-92B, PRO-96
Uniden: BCD396XT, BCD436HP+DMR & NXDN
Motorola: APX6000XE
Baofeng: RD-5R
Old 01-14-2018, 12:02 PM
Unless they did away there used to be a assistance patrol in the west memphis areas on I40 and I55 corridors. That is the only one i have ever known of in the state
Old 01-14-2018, 1:48 PM
03msc's Avatar
Yes, AHP is dispatched from one center in LR. ASP is dispatched at each troop HQ for that troop.
Mark Arkansas
Old 01-14-2018, 1:49 PM
03msc's Avatar
jbdinki,
Thanks for the map - I haven't seen that before and we've looked for it. I think milf probably remembers those discussions, too, as someone would always show up and argue that ASP and AHP were the same thing and (as you know) they aren't.
Mark Arkansas
Old 01-14-2018, 2:28 PM
Arkansas Highway Police - The RadioReference Wiki
Old 01-14-2018, 2:53 PM
People tend to get confused because asp calls their patrol troopers the highway patrol division of the arkansas state police
Old 01-14-2018, 2:56 PM
03msc's Avatar
That's probably true...and understandable when you consider that, I suppose.
Mark Arkansas
Old 02-22-2018, 10:36 AM
HogDriver's Avatar
Only thing is, the map lists 5 districts but AWIN calls out 6.
Old 02-23-2018, 7:24 AM
I have never been able to confirm that there is any traffic of District 6 radio ids. have ran across alot of wrong info all over the database. Anyone ever herd traffic of this ID?
Old 02-23-2018, 7:57 AM
03msc's Avatar
I was thinking the same but since I don't travel the entire state I thought it may just be because I'm not near a tower with a D6 radio affiliated with it. I am in D5 (so AHP D2).
I think the database in wrong on that one - a db admin could probably look back and see where the info came from but I think it was erroneous. There are only 5 AHP districts by all indications from resources.
The db is only as good as the info that people submit to it for the admins to update.
Mark Arkansas
Old 02-23-2018, 8:10 AM
I know they have a roving unit, I.E. huge wrecker and clean up units also could be link between ahp and adot units. I have herd traffic on all area dips except #6
Old 02-23-2018, 7:25 PM
03msc's Avatar
I didn’t know they had any wrecker or anything but maybe it stays down around I40 and stuff. But same here...nothing on those TGs heard by me either.
Mark Arkansas
