Go Back   The RadioReference.com Forums > Canada Radio Discussion Forums > Atlantic and Maritime
Atlantic and Maritime - Forum for discussion of radio information in the Newfoundland and Labrador, Nova Scotia, New Brunswick, and Prince Edward Island provinces.
  #3621 (permalink)
Old 12-16-2013, 4:11 PM
Can any fellow PlanePlotter users have a look and see if I'm (xd) visible now? I think I found my issue thanks to Ian and the PlanePlotter forum.
  #3622 (permalink)
Old 12-16-2013, 4:38 PM
looknlisten's Avatar
Originally Posted by N1RGR View Post
Looks like AR020 at 2245z.
Comms on AR primary at 2236Z.
  #3623 (permalink)
Old 12-16-2013, 4:39 PM
I'll be at my station in 1/2 hour...I'll let you know.
  #3624 (permalink)
Thanks Look. I like my chances. Ugh that was bothering me for weeks.
  #3625 (permalink)
Old 12-16-2013, 4:47 PM
ETHYL55 has the block FL250-270. Receiver (SNOOP55) wants 60k. 2245Z
  #3626 (permalink)
Old 12-16-2013, 5:18 PM
Thumbs up
Looks good here!
  #3627 (permalink)
Old 12-16-2013, 5:20 PM
I was getting "Network Error 183" in spite of my attempts to correctly port forward. I wasn't getting this until I switched the port and began to successfully share data/show up in the sharers list. I disabled the UDP/IP Output's "Enable" checkbox and it went away. I can still MLAT and can still share data (Thanks for looking..Look! ) so I'm thinking things are all ok.
1.Please check your Options..I/O settings dialog.
2.Have you enabled the UDP/IP output - most probably with an IP address and/or port that did not exist or was not open.
3.Disable (uncheck) UDP/IP output unless you know what it is for, and are actually using it.
  #3628 (permalink)
Old 12-16-2013, 5:37 PM
maine87heavy's Avatar
Lima Charlie, xd!
KC1AXY
UNIDEN BCT15X, BC125AT, GRUNDIG G3, BAOFENG UV-82
PlanePlotter Ground Station 'aF' located at KBGR
Mobile PlanePlotter 'Pz'
  #3629 (permalink)
Old 12-16-2013, 5:38 PM
Fantastic! Thanks!
  #3630 (permalink)
Old 12-16-2013, 5:41 PM
ETHYL55, MAINEiac tail 58-0098, I think they are still out there?
KC1AXY
  #3631 (permalink)
Old 12-16-2013, 5:55 PM
Looks like they're on the return leg - I'm getting em increasing signal strength again after they dropped off for a while.
  #3632 (permalink)
Old 12-16-2013, 5:58 PM
Xd where are you located?
KC1AXY
  #3633 (permalink)
Old 12-16-2013, 6:01 PM
I'm in Halifax, not too far from Ian, LS, and the other locals here.
  #3634 (permalink)
Old 12-16-2013, 6:06 PM
Sig test!
PlanePlotter Ground Station xd
  #3635 (permalink)
Old 12-17-2013, 4:02 AM
Default AR20 active 1000Z
ETHYL52 (58-0084 KC-135R) is set to deliver 60K to an unknown receiver at 1020Z
Moncton centre cleared ETHYL on AR20SW near Halifax FL210-230 with receiver at 1008Z
Receiver looks to be SHUCK82 (E-3B 79-0003).
1023Z SHUCK82 has shut off his transponder and refueling has begun.
Refuel completed at 1100Z
  #3636 (permalink)
Old 12-17-2013, 4:33 AM
Looks like the Halifax crew Sharers are working fine...
  #3637 (permalink)
Old 12-17-2013, 6:34 AM
The audio from this morning's refuel on AR20SW of SHUCK82 (E-3B 79-0003 from Tinker AFB) and ETHYL52 (KC-135R 58-0084)
https://audioboo.fm/boos/1802353
  #3638 (permalink)
Old 12-17-2013, 9:03 AM
NE1C4NSC4N's Avatar
Sounds like a REACH flight just finished AR with ETHYL85.
  #3639 (permalink)
Old 12-17-2013, 9:25 AM
saw the C-17 from work. Looked like a red with yellow border flash on the tail. But as of March 10-0221 was a Charleston plane so maybe I mis-saw.
  #3640 (permalink)
Old 12-17-2013, 10:44 AM
NE1C4NSC4N's Avatar
I never did get an eyeball on him, too cold
Just had a hit on 234.7 a few ago, anyone else catch that? BRUISER01 is on now 12:49.
