Anyone know if this scanner will work for the RNC with the new software?
C Ciderjoe4 Member Joined Nov 4, 2009 Messages 2 Location Newfoundland Jan 13, 2017 #1 Anyone know if this scanner will work for the RNC with the new software?
Deziel0495 PE/NB Database Guy Database Admin Joined Feb 11, 2008 Messages 909 Location PEI Jan 13, 2017 #2 Ciderjoe4 said: Anyone know if this scanner will work for the RNC with the new software? Click to expand... If the RNC are still using their EDACS system and are not encrypted, yes. This scanner will work just fine.
Jay911 Silent Key (April 15th, 2023) Feed Provider Joined Feb 15, 2002 Messages 9,378 Location Bragg Creek, Alberta Jan 13, 2017 #3 I believe the RNC use AEGIS digital instead of ProVoice. I didn't get anything when I was on the island last fall.
C Ciderjoe4 Member Joined Nov 4, 2009 Messages 2 Location Newfoundland Jan 17, 2017 #4 Not sure what they use but they are encrypted. I thought the new software would get past that. Thanks
Deziel0495 PE/NB Database Guy Database Admin Joined Feb 11, 2008 Messages 909 Location PEI Jan 17, 2017 #5 Ciderjoe4 said: Not sure what they use but they are encrypted. I thought the new software would get past that. Thanks Click to expand... If they are encrypted then you're out of luck. No scanner can decode encryption.
P primehifi Guest Jan 18, 2017 #6 It is not provoice. They do not use enc on their current aegis digital system.
