Go Back   The RadioReference.com Forums > International Radio Discussion Forums > Australia Radio Discussion Forums
Australia Radio Discussion Forums - Forum for discussing Radio Information in Australia.
Old 03-17-2014, 12:29 PM
Default Set up FRNSW on my UBCD396t
Hi I'm a newby
Need help to program my scanner.
Not shore where to start.
Old 04-10-2014, 7:49 PM
Hi there,
For starters are you in a GRN area or further out in the PMR area. Basically what area do roughly live in?
Cheers
Matt
www.goulburnscan.com
Your source of scanning in the Southern Tablelands NSW.
Old 04-25-2014, 2:31 PM
Hi Matt
Yes I am at Wyong and it is a grn area
Thanks Rob
Sent from my iPad using Tapatalk HD
Old 04-26-2014, 4:32 AM
teufler's Avatar
I am asking what is GRN and PMR areas? I'm here in the states and was reading your thread.
WD0GSYDMR ID 3129226 AND 3129304
BC-396XT,780XLT,TENTEC PARAGON, TYT-2017, MD-390, DM-5R+, ANYTONE 5888,VX10, VX7, VX3,TERMN-8R, F8-HP, GT3, UV-5, UV-3R, WOUXUN UV-8D,JUENTAI UV8DR,
Old 05-13-2014, 7:44 AM
Hi all, yeah pretty easy to setup the GRN into the 396t tell tge software it's a motorola p25 system put your control channel frequencies in and put in trunk option the base frequencies of 412.475 step 6.25khz. Then start puting talk groups in and all should be ok.
Teufler, certain agencies work statewide like fire rescue NSW and Ambulance service NSW. We have a mororola p25 trunking system called the GRN or Government Radio Network. operating around 400mhz covering an area of 102,000sq miles or 1/3 of NSW. OUtside of the GRN these agencies go over to their own (for now anyway) PMR (conventional) network.
Cheers
Matt
Old 05-14-2014, 5:57 AM
Default Thanks mate
Hi Matt
Will give it a go thanks for your help.
Rob
