Old 12-08-2009, 9:57 PM
Skypilot007's Avatar
Question Feeds won't reconnect
I had to reboot my pc that my feeds are on and I'm having trouble reconnecting. I've been using Simplecast to send the feeds. When I try to connect I get error (11004). I have not updated the server details in Simplecast since the move from ScanAmerica. Could this be my issue now. If someone can point me to what I should have in the "server details" tab in Simplecast we can start there. Any other suggestions appreciated.
Old 12-09-2009, 6:47 AM
I noticed the ScanAmerica domain expired recently. On your "manage my feed" page, you will have something called "Feed Technical Details (Advanced)" down towards the bottom. The settings that you need to change will be listed there. You are correct in the only thing you should have to change to get it working again is the "server" part of it.
Old 12-09-2009, 7:52 AM
I had the same problem as well. I had to add an encoder then change the server address to the one listed in my manage feed area. It appears to be back online now. Hope that helps.
Old 12-09-2009, 8:52 AM
Thanks people. I'll get that back online when I get home this evening. I haven't had much time to explore the new online feed area's of this site.
Old 12-09-2009, 9:15 AM
hoser147's Avatar
I had the same problem this morning, had to download and open the Zip file for RR. Opened the connection changed it to the proper settings for 2 channel and joint stereo feed and reset the bitrate to 32. and all seems well. This is if you are feeding 2 scanners to 1 feed.
Good Scanning Hser
http://www.radioreference.com/apps/audio/?feedId=165
Old 12-09-2009, 12:31 PM
Stavro35's Avatar
My feed is back on line. But I think the scanamerica.us is still down
Primary scanner BCD 436HP secondary Pro163,Pro 164 Pro106,GRE PSR 500
Old 12-09-2009, 2:20 PM
Well I didn't change anything. My brother just hit me up and told me they both auto reconnected this morning. All my settings are still set for scanamerica.us. I'm gona roll with it for now.
Old 12-09-2009, 5:09 PM
firescannerbob's Avatar
I had the same problem this morning after re-booting the computer after some Microsoft updates downloaded. Even after several re-boots, I couldn't get both feeds to reconnect, and had to go to work with them down.
They came back up on their own later, so no idea what changed. To my knowledge, all my settings are current, as per the most recent e-mail I got about it (some time ago).
I guess as long as it's working...
-Bob
My online feeds, broadcasting Colorado Springs and El Paso County fire traffic, and the Colorado State Patrol in Pueblo and El Paso Counties: http://www.radioreference.com/apps/audio/?ctid=261
Old 12-09-2009, 5:18 PM
hoser147's Avatar
I think the Microsoft updates brought on alot of the issues. I came in to a black screen early this morning, rebooted and got a message that they had updated. Seemed like a good time for me to change the software from ScanAmerica over to RR, which I had put off for a while.
Good Scanning Hser
