Old 01-05-2010, 6:43 PM
Default Need Help Getting My Feed Going
Im trying to get my feed going, but I keep getting this message (unable to connect to socket) in the Oddcast V3 encoder window. It is trying to reconnect every 30 seconds but I've had no luck. Is this nornal?
BTW I posted this in another sub forum(software), but no luck. I figured this would be a better place to try.
Old 01-06-2010, 9:18 AM
richtidd's Avatar
Live Audio Administrator
Try ScannerCast & see it will work better:
ScannerCast Setup Instructions - The RadioReference Wiki
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 01-07-2010, 4:22 AM
Default thanks
Yup, Scannercast solved the problem. Thank you!
Old 01-11-2010, 9:25 PM
Default Need help still...
Hi-
I tried ScannerCast since I had the same problem with Oddcast, but it says:
Error status from IceCast.
HTTP/1.0 401 Authentication Required
WWW-Authenticate: Basic realm= "IceCast2 Server"
Have any ideas?
The Oddcast on another computer of mine works ok.
Old 01-11-2010, 10:21 PM
Originally Posted by firemedicadam View Post
Hi-
Have any ideas?
I am getting the same error as this as well as the same error on oddcast listed before.....
Old 01-12-2010, 1:16 AM
Maddog1404's Avatar
My Icecast does the same thing with the socket problem. The only way I have found to fix it is to restart the computer
