Old 06-22-2011, 1:27 PM
Default Windows 98 SE
I am considering another feed but the only computer I have available is running Windows 98 SE. Is there a version of ScannerCast or another program available to run on this Operating System.
Old 06-22-2011, 4:21 PM
nunyax's Avatar
When I was running feeds on a Windows 98 SE PC I used Oddcast/Edcast.
Alternative Broadcasting Software and Clients - The RadioReference Wiki
It worked well but I finally moved to XP to use logmein for remote access.
Joe
Just one of the "little scanner people."
Old 06-22-2011, 4:58 PM
ProScan's Avatar
RadioFeed should work with WIN 98. I say "should" because I haven't tested it with that OS in about a year but it should be ok.
Old 06-22-2011, 11:10 PM
Bellingham_Scanner's Avatar
If it can run Win98 then is can run a lighter version of Linux like Xubuntu.
Then run DarkIce to provide your feed.
That's what I use and besides my RR stream I also host two stream directly and the website for my streams.
