Old 08-28-2012, 2:14 PM
Phil1598's Avatar
Default feed issues
I finally got my scanner connected to the computer. I went to listen to my feed and is says not connected. what am I doing wrong?
Old 08-28-2012, 4:00 PM
Default re: feed issues
Hi,
First, make sure you are connected to the Internet (obvious, but you'd be surprised).
I'm assuming you have already submitted your feed and had it approved?
If not, than that's probably your issue.
Once your feed is approved, you enter your RadioReference username and password into ScannerCast, and your feed name should appear in the
'Feed to Send' field. If it doesn't, then
1) You mistyped your login info, 2) your feed hasn't been approved yet or 3) there's an issue on RR's end.
Also, antivirus software (especially AVG), can erroneously block ScannerCast from connecting. Try disabling your antivirus/firewall, then connect again.
Hope this helps!
Old 08-28-2012, 4:28 PM
Phil1598's Avatar
Default thank you
where can I find scanner cast? I may have missed this step.
Old 08-28-2012, 4:32 PM
richtidd's Avatar
Live Audio Administrator
You will find it in the technicles tab of you feed page.
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 08-28-2012, 5:16 PM
Phil1598's Avatar
I was able to get my feed running but it is still not connected. under my feed status it still says coming soon. can you please help again?
Old 08-28-2012, 5:28 PM
W8RMH's Avatar
Your feed is up and running. Whatever you did to the scanner it Sounds Great.
SKYWARN SPOTTER Unication G4 BCD436HP-DMR Home Patrol 2 BCD996XT BR330T
