who do i need too talk too about this i just feel its not working out i can only do so much too my scanner too get it clear thanks for allowing me too run one but i need too do other things just need too know who too talk too about removen my feed
ok thank you ill still vist the site but shutting down the feed hopefully someone witha better sounding feed will take its place cause mines horrable in my option
the more i think about it the more i think i may shut my feed down its fun too let others hear it but being im still new too the pro-197 i have too reprogram alot and it may be annoying too people and it shows in my total lstnes atm but i cant just not learn so if it goes down this time might be for good not sure yet
hmm i listen too other feeds and think why am i streamming i enjoy it but my feeds not doing well and its not as clear as others ive tryed too improve it not working so may just take mine down let the 3 weeks pass and just listen too other btw awsume job too the ones i listen too lpad hot shots tenn feeds ga feeds and bamma and michigan feeds..im from grand rapids well actually from jenison so i thank the ones who stream that its been fun streamming but i enjoy hearing eveyones feed mines not doing the job so ill make way for someone who can do better ill still renew my permum subscription but i may not stream live nomore anywho thanks too thoses who have listend too it hopefully someone can do better witch should be aproblem God Bless
Using config file: /usr/share/doc/darkice/examples/darkice.cfg
Using OSS DSP input device: /dev/dsp
DarkIce: LameLibEncoder.h:115: specified bits per sample not supported [32]
i get that error when i use 32bit it sounds like that ina can sounds horrable any help id be greatful ;/
