Old 08-21-2015, 5:45 PM
blantonl's Avatar
Founder and CEO
Default Broadcastify Raspberry PI Image Available
I've created a preconfigured installation image for the Raspberry Pi2 for broadcasting to Broadcastify:
It is also preinstalled with all the binaries and configuration files for these setup instructions as well:
The image includes the following precompiled applications
  • rtl_fm and the rtl_sdr libraries (latest release
  • rtl_airband build for broadcastify (rtl_airband_bcfy)
  • ezstream
  • darkice with mp3 support
  • Kalibrate-RTL (kal) for determining a dongle's ppm using GSM channels
Enjoy!
Lindsay C. Blanton III
CEO - RadioReference.com / Broadcastify
Facebook: RadioReference | Broadcastify | Twitter: @RadioReference
Old 08-24-2015, 10:11 PM
Lindsay,
Will this build support alpha tags? Is it possible?
Old 08-25-2015, 7:59 AM
blantonl's Avatar
Founder and CEO
Not yet.
There isn't any Linux software support that I'm aware of for Alpha tags at this time.
Old 08-25-2015, 10:00 PM
Default Multiple feed from same Pi and SDR-RTL
Lindsay,
Can you walk me through setting up 3-4 feeds using the same SDR-RTL with your RasPi image loaded on the Raspberry PI 2 b? I am setting up multiple devices at remote locations to get better coverage of LA County.
I also need it to auto load on boot.
I have read several threads and have tried several setting but have not been able to get multiple feeds working on same device.
Thanks for the help
Old 08-26-2015, 7:57 AM
blantonl's Avatar
Founder and CEO
I'm not sure what you mean by "walk you through" - the guides are pretty detailed.
What specific issues are you having?
Old 08-30-2015, 12:38 AM
Smile Thank you!
Lindsay,
Thank you so very much for putting together a fool-proof image. I gave up on the Pi 1 and never revisited it. Just got a Pi 2 and was eager to try it. It took less than 30 minutes from start to finish. I can finally retire that old PC and save on power.
Chance
Old 09-26-2015, 2:22 AM
Default oh no
OK, I seemed to follow all the instructions.
But... I don't seem to be transmitting
Old 10-30-2015, 6:15 PM
Chronic's Avatar
Default DSD+
any plans to add dsd+ to the image ?
Old 11-20-2015, 7:21 PM
This is a bummer.. I was totally looking forward to doing rasp pi but apha tags is a must.
Old 11-20-2015, 8:54 PM
I followed this wiki to get mine running.
I did this command but it doesn't load on boot. Any idea what might be wrong?
Enable the feed to start broadcasting at boot
sudo update-rc.d darkice1 defaults
Old 11-22-2015, 6:47 PM
Default Auto Starting...
The instructions are spot on as it concerns inserting the command to autostart the feed. I will try to help you if I can. What exactly is not working? Just the auto start?
-Brad
Old 11-22-2015, 7:27 PM
By auto start should the command window come up alone and run the start command automatically? It didn't when I had it still booting in command where I had to enter the username and pw. I changed the settings to boot to UI. Should it/can the feed still auto start that way too?
Old 11-22-2015, 8:00 PM
Never mind. I guess it does auto start just doesn't do anything visually. I rebooted my pi and left it alone. Checked my feed 20 seconds later and it's broadcasting.
Old 12-01-2015, 1:08 PM
trooperdude's Avatar
These would be great as a pre-configured appliance.
Hint, Hint
http://www.firesafecouncil.org/
Be Fire Safe California !
Old 12-01-2015, 1:47 PM
kb5zcs's Avatar
Thanks Lindsey been wanting to try this for a long time now,something new to play around with......
http://www.qrz.com/db/kg5euu
Brownsville Digital Group A.R.C.
WORKING THE WORLD WITH 5 WATTS AND A RUBBER DUCK.
Old 12-02-2015, 10:40 AM
I'll be doing this soon, good to get off the decade old server.
Is the RTL-SDR version intended to take the place of a conventional scanner?
Or asked a different way, at the bottom of the wiki for the RTL it mentions soundcard and scanner. What is the difference between the two Pi setups if the soundcard is used on the RTL setup?
Joe
Old 12-02-2015, 11:40 AM
ScannerDude244's Avatar
Originally Posted by LACoFD View Post
Lindsay,
Thanks for the help
Did you ever get the multiple feed going?
still a noob in scanners
Old 12-08-2015, 3:26 PM
Volfirefighter's Avatar
Can anyone recommend a place to purchase a kit (board, power supply, SD card, case) that accepts Paypal. Amazon does not accept Paypal.
Capital Punishment: The only penalty with a recidivism rate of 0%
-Stephen
BC780XLT, BC785D, BCD996T, BCD996P2, BCT15X, PSR600, PRO197, PRO2067
Old 12-08-2015, 4:47 PM
Tryton's Avatar
Ebay?
Equipment:
2 Uniden Bearcat BCD996XT's
2 Uniden Bearcat BCD536HP's
Software:Proscan
Old 01-03-2016, 1:15 AM
Hello out there,
I have had my Pi running for a couple weeks. I just powered the unit down and back up and I cannot seem to get the auto start to fire up. I can't get it to fire up even from a command line.
Nothing had changed on it and i have gone back on the unit and compared it down from the config above and elsewhere on the forum and all looks well.
Anyone have any advice for service start issues? The only thing I have found on the forum is the Comcast proxy issue and this above of waiting. Any other issues folks have seen with even getting it to start via command line?
Thank you,
Joe
