Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 08-30-2009, 1:57 PM
Default HELP! Audio problems
my scanner feed for Polk County is connected but I have no sound. I have tried line in as well as mic inputs. Volume is turned up
Should metadata fields in OddcastV3 be empty?
Old 08-31-2009, 6:19 AM
richtidd's Avatar
Live Audio Administrator
I guess you are saying the scanner headphone out is connected to the computer audio input.
You may need to select the input type in your computer audio settings or the sound card settings. Depending on what your set up is, you maybe using the mic input or a line input.
Oddcast should also detect the audio settings but you may need to manually select. This needs to be set for the correct input. Look at the Live Recording window in Oddcast.
What you are looking for is the right input setting on the computer & through Oddcast.
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 08-31-2009, 7:12 AM
Thanks for responding..I checked input settings first ..it's deeper than that.
Old 08-31-2009, 7:47 PM
richtidd's Avatar
I will regenerate the feed for you so you will get a new e-mail & Oddcast to try out.
Richard Tidd
Broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 08-31-2009, 7:50 PM
richtidd's Avatar
Correction.
I meant I will regenerate the set up.
You have a new set up waiting for you in e-mail.
Richard Tidd
Broadcastify.com
My online scanners:
SMCo, Tuolumne Co
