Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
  #21 (permalink)
Old 02-09-2010, 9:06 PM
DELCOLHFC's Avatar
Thumbs up
Working well here also, hopefully there are plans to make the tags just a wee bit larger so they can be read with my old tired eyes.
Keep up the good work!
I keep a scanner on just to hear what my wife THINKS they just said.
"Police are putting CHOP STICKS in the road?" Gotta love her!
Tri-State live feed http://delaware.pa.scanamerica.us/index.php
  #22 (permalink)
Old 02-09-2010, 10:56 PM
jobes's Avatar
Using Firefox try zooming (ctrl and +) I tried the page zoom with IE and it didn't work with Exploder
Originally Posted by rwmitchell View Post
I've been using the new player all day. I have had no problems and simply love the Alpha display. I noticed on two of my computers I was able to display the "PL" or play list. On the other two, it would not display. That is a function of the display settings thought and not the player.
Audio is great and it seems to run faster than the old players.
Bottom line, It's Great! Good Work to evryone.
Bob
  #23 (permalink)
Old 02-09-2010, 11:33 PM
Java player has been working here without issue.
Also, thanks for implementing the new status/details features in the web player page!
  #24 (permalink)
Old 02-10-2010, 1:54 AM
It buffers all the time, it will restart every 5 to 10 minutes and also i dont know if this have anything to do with you or not but the new IPN device that is on the site seems to not be working either now i have to go to the bottom of the page and click and open a new window to play the java player or the web player. But really it buffers for about once every 5 to 10 minutes and then I will have to restart the whole page as in go back to main site and pull it up again its just not working right I guess for me.
  #25 (permalink)
Old 02-10-2010, 2:11 AM
Smile Java Player
First of all I'd like to say how thrilled I am to find you. I was a daily listener to BerksCo.Live scanner in Pennsylvania. I hate to report the site was closed. I never thought I'd find another site and here you are.
Ok, now the feedback. I became a member and downloaded the new Java player and it was very easy to do and I have had great connection from the min. I started it. It is working wonderfully.
So thank you again for the site and wonderful scanner feed!
A new daily listener,
Michele
  #26 (permalink)
Old 02-10-2010, 6:59 AM
n5usr's Avatar
Ah, perhaps I've found a possible reason some are reporting that the player "goes back" to the original?
I had the list of streams for my area pulled up, opened the Java player in another tab. Had some funky trouble at one point (more on that follows) so I closed the player tab and reopened it from the same stream list in the original tab. I could only get the original Flash player, even when I selected Java player from the pulldown list. Reloading the page let me select the Java player again.
Now, the funkiness that started all this: I started to get echoes. Someone would start talking, then a few seconds delayed the exact same audio would come across again. That could have been something on my end - I was fiddling around with some browser settings and the player page got reloaded (like hitting the Reload button, but that's not what I did). Maybe two instances got loaded up, one slightly lagging the other? At any rate, closing the tab killed them and the newly reopened player is working fine.
This is all in Firefox on XP.
  #27 (permalink)
Old 02-10-2010, 10:16 AM
Anyone running this in windows mobile 6.1? I already listen with my htc phone, but it would be sweet to use the java player and have alpha tags!
  #28 (permalink)
Old 02-10-2010, 11:41 AM
For alpha tags, you are better off using a program player (I currently do on WM6.1). I recommend Pocket Player.
  #29 (permalink)
Old 02-10-2010, 11:53 AM
Well I see that for cumberlan county maine that alpha tags are streaming but I just assumed that was only streaming for the java player.
  #30 (permalink)
Old 02-10-2010, 11:56 AM
There are many players that offer alpha tags... in fact, I'm making one now.
  #31 (permalink)
Old 02-14-2010, 12:57 AM
joescanner's Avatar
Just another radio geek.
One oddity I have noticed, is that with two different java players open (two different windows), the tags will "bleed" between sessions. May not be correctable, depending on the isolation of the java client.
Joseph Stein, KD7MLG
  #32 (permalink)
Old 02-14-2010, 4:20 AM
saveourtrainsmichigan's Avatar
I am using the Java player all the time no issues here works great.
  #33 (permalink)
Old 02-14-2010, 10:05 PM
I just discovered this, great addition to the site.
--Patrick
  #34 (permalink)
Old 07-31-2013, 11:51 AM
Are their any plans of making a player that actually scans so we could load our favorites in and when they stop talking they move on like a real scanner?
Thanks Brian
  #35 (permalink)
Old 07-31-2013, 12:08 PM
Thanks Brian
There's one here:
ScannerLive
Tags
folks
