Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 03-22-2010, 8:29 PM
N7UWX's Avatar
Angry Microsoft .Net error
Hello All,
Just geting started with this live audio stuff.
I have a problem when I try to start up ScannerCast. I get a Microsoft .Net Framwork error! See text below.
I have 2.0 framwork installed on a Win 2000 machine.
Thanx,
Tyler
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.BadImageFormatException: The operating system cannot run . (Exception from HRESULT: 0x800700B6)
at Istrib.Sound.SoundCaptureDevice.get_AllAvailable()
at ScannerCast.ScannerCast.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1873 (QFEN-1.050727-1800)
CodeBase: file:///c:/WINNT/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ScannerCast
Assembly Version: 1.0.0.0
Win32 Version: 0.13.1224.0
CodeBase: file:///C:/ScannerCast/ScannerCast.exe
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Istrib.Sound
Win32 Version: 1.0.0.0
CodeBase: file:///C:/ScannerCast/Istrib.Sound.DLL
Istrib.Sound.Mp3
CodeBase: file:///C:/ScannerCast/Istrib.Sound.Mp3.DLL
Old 03-22-2010, 10:33 PM
Astrak's Avatar
I believe you need .net3.5 http://www.microsoft.com/downloads/d...displaylang=en
WWW.APSN.US
Old 03-23-2010, 6:46 PM
N7UWX's Avatar
I'm running Windows 2000 on this machine and it needs .Net 2.0
Latter versions need XP or better.
I'm trying to reinstall 2.0
Tyler
Old 03-23-2010, 9:00 PM
Originally Posted by Astrak View Post
I believe you need .net3.5 Download details: .NET Framework 3.5
ScannerCast requires .NET 2.0, anything newer is optional.
Checking .NET for K1PGV Utilities
Old 03-23-2010, 9:13 PM
PeterGV's Avatar
K1PGV, ScannerCast author
I have no idea what the problem is. My suggestions:
1) Remove and re-install .Net V2.0
2) When you download ScannerCast, make sure you extracting EVERYTHING from the DLL, and put it a brand new, empty, folder. The folder from which you run ScannerCast should have the following files (and NO OTHER files with file types of .exe or .dll):
Istrib.Sound.dll
Istrib.Sound.Mp3.dll
lame_enc.dll
Microsoft.DirectX.DirectSound.dll
Microsoft.DirectX.dll
ScannerCast.exe
yeti.mmedia.dll
yeti.mp3.dll
Aside from that... I'm out of ideas. It's GOT to be some sort of .Net or DLL problem. I've never heard of this problem, and searching with Google yields a few (not many) similar reports with various utilities written in C# and installed on Windows 2000... but sadly no solutions.
Sorry you're having trouble,
Peter
K1PGV
Old 10-06-2010, 9:05 AM
byandrewdavis's Avatar
I've got the same scenerio.. win2k, .NET 2.0 and the exact same error you're getting.
What do you end up doing about it?
Thanks!
Tags
.net
