Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 04-15-2010, 2:47 PM
Default ScannerCast
Does anyone know of you can run two different copies of ScannerCast at the same time on the same computer so I can have multiple feeds.
Old 04-15-2010, 5:15 PM
ScanPEI's Avatar
Just give each copy a different name.
Ex: ScannerCast 1, ScannerCast 2, ect.
Daniel Deziel
ScanPEI.net
Database Admin for Prince Edward Island and New Brunswick.
Old 04-15-2010, 5:53 PM
ScannerCast Setup Instructions - The RadioReference Wiki
Old 04-15-2010, 7:29 PM
Easy,
Create a shortcut for each feed you will need. For each feed you will need to edit each shortcut (don't forget to rename the name of each shortcut as well ). In the Target Field after ScannerCast.exe add
file with a name like fire.ini, or police.ini , you catch my drift i think.
Click Apply, OK.
When you run each shortcut, setup the feed parameters (either manually or from RR, also under the config tab under the "Server" section each feed will need a unique port number, 5700, then 5701, etc. failure to do so will result in errors when each feed after the 1st is launched)
Start the Feed for a moment, then stop it and exit. Then Restart from each Respective shortcut once each feed is configured.
If done correctly each shortcut should load with the settings of that particular feeds purpose.
--Patrick
