Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 05-15-2010, 9:53 AM
Default Help Fixing Audio Problem with Feed
Hi all, I need some thoughts finding my audio problem. i have replaced the wall warts, added ground loop isolator, new cables still when you run the feed constant hum/buzz. on the player it show up on the left two bars for the equalizer...any thoughts? i even took my 96 out of my trunk to try it!!
Berkeley County South Fire and EMS Live Scanner Audio Feed
thanks in advance
Dan
Old 05-15-2010, 12:56 PM
45SigSauer's Avatar
I've mentioned this a few times to other members, I had a bad hum/buzz on my recordings and feed, and another member mentioned the AGC,
right click your speaker icon.
select recording devices.
select the device for your feed/recording.
select properties.
under the custom tab, uncheck the AGC.
fixed my problem right up.
Proud Member/President: N.A.S.W.P
National Association for the Survival of White People
(Spoof of the N.A.A.C.P to show the idiocy of the racist double standard).
Old 05-15-2010, 2:23 PM
I am actually using one of those little usb cards from china, so it is line in not a mic, can't find a way to change to mic, so no auto gain control (agc) to change....
dan
Old 05-17-2010, 10:55 PM
thanks in advance
Dan
I had the same problem till about 20 min ago. I had gone crazy thinking it was my equipment and tried replacements for it all up to trying a brand new computer. I had to install a new encoder program and them BAM! it was all gone. Alternative Broadcasting Software and Clients - The RadioReference Wiki
info needed to set them up is at end of your feed detail page.
When did you start your feed out of curiosity?
