Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
  #21 (permalink)
Old 05-22-2010, 10:52 PM
kpoe_28's Avatar
I run my Dunklin/Pemiscot Counties Missouri feed with a BCD996XT & Icom IC2200H with a D130NJ 100 foot up,coax is rg11 quad shield, using a Electroline EDA-UG 2802 8-port.
BCD396XT,BC9000XLT,BC895XLT,BC340CRS,Pro95,PX-888,Pro106,Pro433,FT-7800R
Lost in the bootheel!! Somewhere between Tennessee and Arkansas
www.tinyurl.com/kennettscanner
  #22 (permalink)
Old 05-23-2010, 2:04 AM
I use a Philips FM92 transceiver for my feed. Old FM92s are cheap as chips (often free!) around here and I think commercial radios designed for the band have better audio and signal quality than your general DC to daylight scanners. That, plus it's cheaper :-)
  #23 (permalink)
Old 05-23-2010, 2:56 AM
i use one of my PSR500's with tags enabled(and yes i have to sort it out). with that much mixed mode traffic here now, dont have a lot of choice on it anymore.
cheers
  #24 (permalink)
Old 05-23-2010, 9:47 AM
hoser147's Avatar
Split feed here Pro 96 and a Uniden BCT7
Good Scanning Hser
http://www.radioreference.com/apps/audio/?feedId=165
  #25 (permalink)
Old 05-23-2010, 3:02 PM
Default Scanners used in feeds
Norfolk, VA Fire-Rescue feed=Bearcat 895XLT w/ 1/4 wave wire antenna (bent paper clip)
Chesapeake, VA Fire Dept feed=RS PRO-197 w/ stock antenna
  #26 (permalink)
Old 05-27-2010, 9:38 PM
fredva's Avatar
I'm using a Pro-2052 for one feed that includes EDACS trunking. Recently set up another feed using an old Pro-2021, and have used a Pro-2020 in the past.
If only conventional analog is being monitored, one feature that could be considered an advantage on the Pro-2020, Pro-2021, and few other scanners is that you can use the RCA tape out jack for the connection to the computer. This means that you can listen to the scanner as normal, through the scanner speaker, and adjust the volume up or turn it all the way down, while the streaming audio feed remains at a constant volume. The scanner speaker is not silenced as it would be when you plug into an earphone jack. That may or may not be an advantage, depending on your setup and preferences.
RS PRO-18, RS PRO-197, RS PRO-2052, Uniden 436HP
Fire & EMS feeds: http://www.broadcastify.com/listen/feed/527 & http://www.broadcastify.com/listen/feed/3331
  #27 (permalink)
Old 05-28-2010, 3:09 AM
I have a stereo feed. I use a Uniden BC780XLT to monitor regular police, fire, and the local sheriff for left channel. Then have a PRO-528 monitor CHP only for right channel. Both are hooked up to an Antennacraft ST2.
Scanners: Uniden BC780XLT | (2) RadioShack PRO-528
Antennas: Antennacraft ST2, Antennacraft ST4
http://www.radioreference.com/apps/audio/?feedId=3446
