Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 01-21-2011, 12:26 AM
Default Player Selection
No matter what player I select, Winamp always opens. I can select ITunes and Winamp opens. Or I can select Windows Media Player and Winamp opens. Any help would be much appreciated.
Old 01-21-2011, 8:10 AM
NYRHKY94's Avatar
You probably need to go into Option / Preferences / File Types in WinAmp and uncheck the file types boxes that are associated with the other players. Each player will have a preferences section where you can check off the types of files they are associated with. Right now, it sounds like your WinAmp is associating with all file types and that's why it is the only player opening. You can also go into Windows (Control Panel) and asscoiate certain files types to always open with certain players.
PSR600/PSR500/PRO197/BCD996XT/BCT15X/BCD536HP/BC210XLT/BC370CRS
Old 01-21-2011, 9:16 AM
If you continue to have trouble, try following this procedure, under "To change which program starts when you double-click a file:"
How to change or select which program starts when you double-click a file in Windows XP
A lot of media programs (like WinAmp) like to "grab" all the file permissions to that everything it can open, it *will* open.
Old 01-21-2011, 10:43 AM
Thanks for your replies. I've tried th change which program is associated with the file types and I still have this same problem. If I associate Itunes to this file type, then Itunes also opens when I select Winamp.
