Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 03-24-2011, 11:48 AM
Default USB sound with line in?
I have successfully installed Scannercast on a Wyse 9150SE XPe Thin Client for hosting my feed. I plan on documenting the procedure and posting it for all to use.
One item I overlooked was the thin client only has a MIC In(mono) and I am running a stereo feed.
Can someone recommend a USB sound adapter with Line In that will work with XPe?
BC780XLT
BCD396T
Old 03-24-2011, 2:24 PM
scancapecod's Avatar
Scan New England Guru
I was able to get a Soundblaster Live! USB 24 Bit External device working with an HP5720 TC running XPe SP2. Of course you'll need to attach an external CD-ROM drive to it to install the software. I chose a simple "drivers only" install.
This device will appear to install as soon as it is plugged in but to properly use the Line In it requires the actual drivers to be installed.
Scott - Scan New England Webmaster
http://www.scan-ne.net
Radio Reference MA, RI, & CT Database Admin
Old 03-24-2011, 3:46 PM
richtidd's Avatar
Live Audio Administrator
I am currently using a iMic on a HP ThinClient.
No problems & any drivers self loaded.
Griffin Technology: iMic - USB Audio Interface
They work great. Switchable Mic or Line
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 03-27-2011, 2:30 PM
Thanks for the input I was able to get a SoundBlaster Live MP3 External for cheap which looks like it is going to work.
BC780XLT
BCD396T
Old 03-31-2011, 11:05 AM
Thanks for the info I was able to successfully get it setup with ScannerCast and a SoundBlaster MP3 external USB sound card.
BC780XLT
BCD396T
