Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 07-26-2011, 5:36 PM
Question Delay for my transmission ?
Hello,
Why do I get a delay of 45 seconds between the transmission's ScannerCast K1PGV RR and retransmission RadioReference.com on the server?
What can I do to improve the delays?
Thank you very much, really great RadioReference.com
Pascal
va2aba
Old 07-26-2011, 7:24 PM
Because it takes time to convert analog audio to digital, upload to server, download to client, and convert back to analog. Plus if you don't buffer it about 30 seconds, you will get a lot of skips and jumps.
Old 07-27-2011, 12:52 PM
Hi rdale,
Ok thank you very much there is a way to transfer directly to the server in digital?
Does it improve the delay ?
Pascal
va2aba
Old 07-27-2011, 2:16 PM
Well you never can completely eliminate the delay - it's just physically impossible. It can be done with special streaming software, but it's much more intensive. Plus again it would require every listener to have perfect, uninterrupted bandwidth. Not many of those ISPs exist.
Old 07-27-2011, 6:21 PM
Rob1956's Avatar
Isn't the delay also considered beneficial because it would mess up the timing of someone doing criminal activity? The theory is that realtime following of police activity would give a criminal an advantage....
Old 07-27-2011, 8:14 PM
No, because nobody uses the feeds to successfully commit criminal activity. They use this new-fangled thing called a scanner if that is their goal
Old 07-27-2011, 8:34 PM
Rob1956's Avatar
...unless they're using an iphone or droid to stream..that is if radioreference has an app..
Old 07-28-2011, 1:24 AM
Ok thank you for all the information, I just wanted to reduce the delays a little bit.
The system is exellent.
Bye
thank you.
