Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 12-15-2011, 9:55 PM
Nate1n22's Avatar
Default Nicecast Issue
I am trying to host my live feed, but whenever I try to start the broadcast it says "Error: Login failed, retry in 10s"
I followed the Wiki page exactly and I still get this error.
Old 12-15-2011, 9:57 PM
Nate1n22's Avatar
And of course right as I post this thread it works.
Just changed the port.
Old 12-20-2011, 8:11 PM
BigEvil's Avatar
What port did you change it to? I receive this error nonstop
Old 12-20-2011, 8:40 PM
ScanPEI's Avatar
The RR Live Audio application normally uses port 80. You can also use ports 8000, 8080, or 8500. The alternate port numbers are typically used to get around firewall problems. You may also need to use port forwarding on your router to allow your feed through.
Daniel Deziel
ScanPEI.net
Database Admin for Prince Edward Island and New Brunswick.
Old 12-20-2011, 8:46 PM
BigEvil's Avatar
I'll mess with port forwarding on my Time Capsule. I tried all four of the ports above but to no avail.....
Does nicecast include tags? I want my listeners to enjoy those.
Thanks much
Old 12-26-2011, 3:32 PM
Nate1n22's Avatar
I'm having this problem again. My computer had to restart, now it will not connect
