Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 03-03-2012, 11:04 PM
Tryton's Avatar
Default usb soundcard
Can anyone tell me if these soundcards are ok to use for feeds? Running Win 7 64bit
Ebay
Equipment:
2 Uniden Bearcat BCD996XT's
2 Uniden Bearcat BCD536HP's
Software:Proscan
Old 03-04-2012, 10:41 AM
I use one of these USB 2.0 to 3D AUDIO SOUND CARD ADAPTER VIRTUAL 7.1 ch | eBay
and it's ok for streaming
The model you posted I use those for my Tapped Scanner for Trunk88 and it works ok for that too. Only thing is they seem to fall apart after awhile I guess the heat and the plastic doesn't work well.
Old 03-04-2012, 10:58 AM
Tryton's Avatar
Thanks Webstar22!
Equipment:
Software:Proscan
Old 03-04-2012, 2:08 PM
I have used both of these and both work ok. The problem I have is that I have 2 feeds running at the same time on 2 copies of oddcast. I have them set to the start up folder so when the computer reboot they start back up automaticly. The problem is they both have the same "name" "generic USB audio something" so the oddcast gets confused on witch one to pick and the audio gets all mixed up and the fire audio ends up on the police feed or vice-versa. I have even had both audios on both feeds.
Makes me wonder how other feed providers do it? How about the NYC feed that uses 10 scanners with 10 of these USB cards?
Any help is welcome.
Old 03-04-2012, 2:36 PM
datainmotion's Avatar
Wirelessly posted (Clacking rocks together: Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; DROID X2 Build/4.5.1A-DTN-150-30) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Windows handling of multiple USBs is the culprit with mis-routing audio. I have 3 feeds running off identical USB audio devices to two websites on the same machine and don't have issues, now that I figured that out. Also, Scannercast can be a victim of this just as easily as Oddcast. One thing I did that seemed to help was to use an externally powered hub, rather than the onboard USB ports.
Travelling through Colorado?
wir hören zu
Old 03-04-2012, 8:41 PM
Ok I agree its windows, and I am using a hub, but how did you get around it? I don't know anything about windows, I just use it. All I want to do is feed 2 or 3 scanners to RR on one laptop and use ProScan to remote control them. The laptop and scanners are in a server room so I don't want to have to reconfigure everything when the thing reboots or updates.
Thanks for your input.
Old 03-04-2012, 9:38 PM
Tryton's Avatar
can anyone tell me if the sound cards listed above can work on win 7 64 bit?
Equipment:
Software:Proscan
Old 03-05-2012, 8:40 PM
NFR85's Avatar
Tryton does not look it supports Windows 7. I use this Amazon.com: Creative Soundblaster X-Fi Go! Pro USB Audio System with THX SB1290: Electronics
And it supports windows 7. The USB you saw on eBay here are the requirements and the link I found it
System requirements: OS: Win98\ME\2000\XP
USB 2.0 3D MIC Speaker 5.1CH Audio Sound Card Adapter for sale
With you living in FL the cost is $41.99 at Best Buy awesome reviews. The one you’re looking at, a lot of people complained of humming noise or low volume.
The Sound Blaster I'm recommending is on eBay here: Creative - Sound Blaster X-Fi Go Pro External USB Sound Card | eBay
Hope that helps! And Good Luck
Old 03-06-2012, 1:10 AM
Are you using a hub with it's own wall wart power?
As for reboots, I bring each one up, one at a time - sorry, that probably doesn't help. You may want to bounce this off the folks at LiveATC.net - they have a number of "Super Feed" sites that I believe are remote only.
wir hören zu
Old 03-06-2012, 6:51 AM
Tryton's Avatar
Thank You, I got a reply from the E-bay seller confirming exactly what you said. Thanks again for your help!
Equipment:
Software:Proscan
