Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 08-21-2012, 8:44 PM
nofdexplorer406's Avatar
Default small bleed over issue
So today i ditched the USB Sound Device and traveled 30 minutes to pick up a PCI sound Card. Purchased a Encore electronic 7.1 for 15.90. Now the problem is my onboard Sound and PCI card are picking up small amounts of audio very low unable to figure it out i got playback muted and using mic in on both onboard and PCI with no mic boost can anyone advise me where to start?
Phillip Garrett
Old 08-21-2012, 8:46 PM
clarify a little more they record and put their designated radio feed just fine they are picking up from each other just a little enough to drive you crazy
Phillip Garrett
Old 08-24-2012, 5:21 PM
n1ti's Avatar
Ground loops is the usual cause. Are your audio cables isolated? (transformer coupling). I had the same problem as well but inserted a 600 ohm line transformer in each cable cure it (and the related hum).
Tim, N1TI
Mattapoisett, MA
Old 09-03-2012, 1:30 PM
Use line-in (the blue port) and not mic-in (red).
