Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
  #201 (permalink)
Old 02-12-2014, 6:13 PM
AC0RV's Avatar
Smile
If I have my feed running can I also listen and videos on the computer or will that interrupt my feed ?
Thanks and Happy Scanning
The only way into heaven is through Jesus.
David F AC0RV
Skywarn # M187201
  #202 (permalink)
Old 02-12-2014, 6:27 PM
Live Audio Administrator
You can as long as your sound card is configured to only record from the Mic In input (which it most likely is).
  #203 (permalink)
Old 02-25-2014, 2:39 PM
ScanPEI's Avatar
Default Transition
Any news or updates on the transition? How are things going? As always, keep up the excellent work!
Daniel Deziel
ScanPEI.net
Database Admin for Prince Edward Island and New Brunswick.
  #204 (permalink)
Old 02-26-2014, 12:45 AM
luke-1's Avatar
I received an upgrade notification a few days ago for my feed (Aurora).
I did the upgrade, everything seems to be fine, however I noticed that it has been going down at night for about 2 hours or so. Are you guys working on the system at these times? I was just curious if this is something I need to address.
Luke
I'm listening to you
MNN 060
KC0VPS
Aurora Online
  #205 (permalink)
Old 02-26-2014, 8:42 AM
Originally Posted by luke-1 View Post
...however I noticed that it has been going down at night for about 2 hours or so. Are you guys working on the system at these times? I was just curious if this is something I need to address.
We haven't been performing any maintenance on the audio servers recently (or in quite a while), they've been up and running for quite some time with no issues.
  #206 (permalink)
Old 06-06-2014, 7:59 AM
Question Reset password
Deleted
  #207 (permalink)
Old 07-30-2014, 2:44 AM
can i stream with Butt butt - broadcast using this tool
and when does the 'coming soon' tag on my stream go away?
  #208 (permalink)
Old 07-30-2014, 8:02 AM
With a recent update, Butt now supports the lower bitrate required by this site to stream a feed. Recommended settings are 16Kbps bitrate and 22050 Hz sample rate for a single channel (mono) feed. More info in the thread linked below and in the Wiki. I'm using two simultaneous instances of Butt on my Windows computer to provide feeds to this site and Weather Underground.
http://forums.radioreference.com/liv...sing-tool.html
I believe the "Coming Soon" tag is removed as soon as your streaming program makes its first connection to the streaming server.
Daily Use: Uniden BC436HP, GRE PSR-800
Other scanners: GRE PSR-500, Uniden BC250D, RS Pro-2052
  #209 (permalink)
Old 08-04-2014, 3:19 AM
  #210 (permalink)
Old 08-15-2014, 10:11 PM
NFR85's Avatar
I'm sure alot of people are aware of whats going on in Louisville. My questions is how does Broadcasify keep up with 58k+ people listening? I know there was sluggish in the past not sure if it was increased to allow more listeners.
  #211 (permalink)
Old 08-15-2014, 10:16 PM
The 58,000 listeners are spread across 4 Icecast audio servers which are very good at handling lots of listeners very efficiently. We had around 80,000+ listeners back when the Boston Marathon suspects were located/chased.
  #212 (permalink)
Old 08-16-2014, 12:10 AM
W8RMH's Avatar
The site was unavailable for a couple minutes about 11:52 PM EDT....and all this due to a hoax. That's one way to get listener rewards I guess.
SKYWARN SPOTTER BCD436HP-DMR Home Patrol 2 BCD996XT BR330T FreeScan Sentinel RadioFeed
  #213 (permalink)
Old 08-16-2014, 12:16 AM
W8RMH's Avatar
Site unavailable again. That feeds needs to be taken down.
  #214 (permalink)
lost_in_maine's Avatar
seems to be still down here...my feed, and can't connect to others
Nice error msg...
Error 503 Service Unavailable
Service Unavailable
Guru Meditation:
Doug-BCD536HP HP-1 x2 BCD996XT
BCD396XT BCD-396T BC9000XLT
ST-2 x3 WBD-40 Discone Grove Scanner Beam
www.wirebridgeweather.com APRSWXNET http://www.findu.com/cgi-bin/wxpage.cgi?DW1694
  #215 (permalink)
Old 08-16-2014, 12:18 AM
The site is still down at 12:18 AM EDT. What hoax?
  #216 (permalink)
Old 08-16-2014, 12:24 AM
Highest I saw was 74,000 listeners.
  #217 (permalink)
Old 08-16-2014, 12:33 AM
W8RMH's Avatar
And it's all a hoax. I spoke to a state police contact of mine and he couldn't stop laughing. I sent Admin an email.
  #218 (permalink)
Old 08-16-2014, 12:35 AM
The calls for service sounded pretty real.
  #219 (permalink)
Old 08-16-2014, 12:48 AM
The feed is back up after the error. Apparently it even affected mobile devices. I have an app called 5-0 radio on my iPhone and that wouldnt even work.
Always enjoying the sound of a tube radio warming up...
  #220 (permalink)
Old 08-16-2014, 12:50 AM
#LouisvillePoliceScanner is trending worldwide on Twitter!
Tags
sticky
