Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 08-02-2013, 6:45 AM
fredva's Avatar
Default iMic question
For those using an iMic for streaming on an XP system, is there a way to get the input coming from the scanner(s) to play through the computer speakers in real-time? I got a used iMic for the stereo line-in capability, but discovered after it arrived that I could only listen to whatever was coming into the iMic in real-time on a Windows 7 laptop. I could not hear the input on Windows XP systems, and I use XP systems for streaming. Looking at the iMic documentation, it indicates that it is primarily for recording software. Based on that, I found that ScannerCast would stream the input of the iMic, but there is no real-time passthrough of the sound to the PC's speakers. I've always used the computer speakers to listen to the scanner in real-time instead of hooking in speakers between the scanner and the PC.
RS PRO-18, RS PRO-197, RS PRO-2052, Uniden 436HP
Fire & EMS feeds: http://www.broadcastify.com/listen/feed/527 & http://www.broadcastify.com/listen/feed/3331
Old 08-03-2013, 6:20 AM
I discovered the same problem when I purchased the iMic for my Raspberry Pi feeds. Great audio, but no local pass-thru. I ended up splitting the scanner output audio through a Y-cable for local monitoring.
BCD396XT | BCD996XT | PRO-136 | BC9000XLT| BC898T
Santa Clarita Valley, CA Live Scanner Feed
Old 08-03-2013, 8:04 AM
fredva's Avatar
Ok, thank you for the confirmation. I tried looking for any Windows sound setting that might allow the pass-through, but to no avail.
Old 08-03-2013, 9:01 AM
Eng3ineer's Avatar
I had the same results as well using the I-mic worked great on my windows 7 laptop, but no go on my older computer. I gave up and started using the Y-cable as well.
