Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 12-20-2013, 4:57 PM
kc0vgj's Avatar
Default Audio Error Status
HTTP?1.1 401 Unauthorized
Scanner Cast PUSH Error 105
what am i doing wrong
O/S Windows 7
I Support Navy / Army / Air Force / Marines and all the personals that keep us safe. However "DON'T" confused this for me supporting the Current Government Body. I DON"T...
Old 12-20-2013, 8:11 PM
kc0vgj's Avatar
User name passes, and password login in great, but error when i try to broadcast.
Old 12-21-2013, 12:54 AM
kc0vgj's Avatar
More Info:
21-Dec-2013 01:53:06 *****************************
21-Dec-2013 01:53:11 Retrieving initial auto-config for user 'kc0vgj'
21-Dec-2013 01:53:12 Selected Feed: Weaverville Police, Fire and Public Works(15821)
21-Dec-2013 01:53:13 Server start requested.
21-Dec-2013 01:53:14 Retrieving initial auto-config for user 'kc0vgj'
21-Dec-2013 01:53:14 Selected Feed: Weaverville Police, Fire and Public Works(15821)
21-Dec-2013 01:53:14 Sound Card: Microphone (SoundMAX Integrated Digital Audio) (1)
21-Dec-2013 01:53:14 MP3 BitRate: 16Kbps
21-Dec-2013 01:53:14 Stream name: Weaverville Police, Fire and Public Works
21-Dec-2013 01:53:14 Connecting to Icecast server audio3.radioreference.com/144768370
21-Dec-2013 01:53:15 Error status from Icecast (105): HTTP/1.1 401 Unauthorized
Date: Sat, 21 Dec 2013 06:53:12 GMT
21-Dec-2013 01:53:17 No further connect attempts will be made (105).
21-Dec-2013 01:53:19 Server stop requested.
21-Dec-2013 01:53:22 Server Stopping Sound Capture.
21-Dec-2013 01:53:22 Server Final Cleanup.
21-Dec-2013 01:53:22 Server Stopped.
Old 12-21-2013, 1:13 AM
kc0vgj's Avatar
the error
Old 12-23-2013, 4:27 PM
Live Audio Administrator
Try installing the non-RadioReference-specific version of ScannerCast ( K1PGV's ScannerCast ) and tell it to connect over port 8000 instead of port 80 and see if you still have the problem.
This will help if the problem is that your ISP (or a network firewall) is blocking the streaming connection.
Old 12-26-2013, 11:31 AM
kc0vgj's Avatar
Sorry no dice still get same error....
Old 12-27-2013, 8:24 AM
richtidd's Avatar
O/S Windows 7
"PUSH Error 105" means that ScannerCast is getting an authorization error when attempting to log your feed onto RR. You may need to retry later.
Make sure your RR/BCFY user name & pass are correct & using the correct case.
You can try these other ports:80, 8000, 8080, or 8500.
Have you tried port forwarding on you're router to allow you're feed through.
Are you using AVG anti virus? If so, get rid of it as it disrupts feed streams. AVG & ScannerCast do not work together.
Also, proxy servers not allowed.
You might also try reinstalling .Net Framework 2.0 to make sure that's not the problem (although, from the error, it would appear that you're running into a ScannerCast bug).
You might try using RadioFeed to provide your feed.
RadioFeed Setup Instructions by Proscan.org. ProScan
Like the RR branded version of ScannerCast, RadioFeed will auto config to your BCFY account and feed.
Once downloaded & installed, simple as:
1 - Log into RR/BCFY and select your feed to broadcast.
2 - Select the correct sound card.
3 - Select Mono for a one radio feed or stereo for a two radio feed where one radio is on the left & the other is on the right. (Presets bit & sampling rate to correct settings)
4 - Press connect.
Basic RadioFeed Stereo Set Up:
Under Server Type, select RadioReference.
Press on RadioReference Auto Configure.
Log into RR (Enter your RR user name & pass).
Press Connect.
Select your feed to broadcast under Description.
Press Set.
Select Mono for a one radio feed or stereo for a two radio feed where one radio is on the left & the other is on the right. (Presets bit & sampling rate to correct settings).
Under the Options Tab, select these boxes: Are you Sure, Start up, Check for newer versions. Others are you like.
Under Source Select Tab, Press connect. You should now be broadcasting.
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 12-28-2013, 4:19 PM
kc0vgj's Avatar
I will try it on Tuesday
Old 12-29-2013, 6:57 AM
I'm getting this too. And all day yesterday and most of last night Icecast was up, down, up & down constantly. Getting this on Audio server-1. I can't even re-connect a feed at the present moment due to this error.
Also getting Scanner Cast start error " The Request Failed with HTTP status 503: service temporary unavailable" at the same time my other feed (Which is connected) is going on and offline every few seconds.
Old 12-29-2013, 9:20 AM
I confirmed that audio1.radioreference.com is stable and isn't going up and down (by going to http://audio1.radioreference.com to see what feed's it's hosting and confirming that several of them have been up for several days (one I checked has been online for weeks)).
-- Gordon
Old 01-12-2014, 4:51 AM
kc0vgj's Avatar
i give up
Old 01-12-2014, 4:52 AM
kc0vgj's Avatar
i used ports:
80
800
and others
Old 01-12-2014, 8:00 AM
richtidd's Avatar
i give up
Your feed for:
Is on audio3, not audio1.
Richard Tidd
Broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 01-13-2014, 8:44 PM
kc0vgj's Avatar
I tried Both
Old 01-13-2014, 9:13 PM
ProScan's Avatar
Could it be that your ISP is blocking outbound traffic on port 80 which is common? I believe their is an alternate port but don't have enough knowledge to go into what's involved.
EDIT
If you tried port 80 and 8000 (not 800) and audio1 and audio3, you may of missed the combination during your trial and error. I would use audio3 as richtidd advises then try port 80 and then 8000. I may be wrong on the 8000 number but it's not 800.
Old 01-13-2014, 10:46 PM
kc0vgj's Avatar
I Finally got the DARN thing to work. Been in the phone with my ISP and the gave me a open port. All this time I thought I was messing up. Nop it Was My ISP.
