HTTP?1.1 401 Unauthorized
Scanner Cast PUSH Error 105
what am i doing wrong
O/S Windows 7
"PUSH Error 105" means that ScannerCast is getting an authorization error when attempting to log your feed onto RR. You may need to retry later.
Make sure your RR/BCFY user name & pass are correct & using the correct case.
You can try these other ports:80, 8000, 8080, or 8500.
Have you tried port forwarding on you're router to allow you're feed through.
Are you using AVG anti virus? If so, get rid of it as it disrupts feed streams. AVG & ScannerCast do not work together.
Also, proxy servers not allowed.
You might also try reinstalling .Net Framework 2.0 to make sure that's not the problem (although, from the error, it would appear that you're running into a ScannerCast bug).
You might try using RadioFeed to provide your feed.
RadioFeed Setup Instructions by Proscan.org.
ProScan
Like the RR branded version of ScannerCast, RadioFeed will auto config to your BCFY account and feed.
Once downloaded & installed, simple as:
1 - Log into RR/BCFY and select your feed to broadcast.
2 - Select the correct sound card.
3 - Select Mono for a one radio feed or stereo for a two radio feed where one radio is on the left & the other is on the right. (Presets bit & sampling rate to correct settings)
4 - Press connect.
Basic RadioFeed Stereo Set Up:
Under Server Type, select RadioReference.
Press on RadioReference Auto Configure.
Log into RR (Enter your RR user name & pass).
Press Connect.
Select your feed to broadcast under Description.
Press Set.
Select Mono for a one radio feed or stereo for a two radio feed where one radio is on the left & the other is on the right. (Presets bit & sampling rate to correct settings).
Under the Options Tab, select these boxes: Are you Sure, Start up, Check for newer versions. Others are you like.
Under Source Select Tab, Press connect. You should now be broadcasting.
