Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 02-28-2014, 7:57 AM
AC0RV's Avatar
Default feed problem
I have my feed connected to the server and but it shows as disconnected. I reconnected the feed and it still show disconnected.
Please help and thanks.
The only way into heaven is through Jesus.
David F AC0RV
Skywarn # M187201
Old 02-28-2014, 8:30 AM
Live Audio Administrator
I checked just now and confirmed that the site correctly lists your feed as being online (although no one will be able to connect to it at the moment).
Old 02-28-2014, 8:33 AM
ScottBL's Avatar
Having the same issue here. Feed was showing online, however I was unable to connect from various different sources.
Old 02-28-2014, 8:34 AM
Correct, there was a problem relay.broadcastify.com, the server that connects listeners to a random audio server that we use for relaying the audio to listeners. I believe the problem is now fixed.
