Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 06-10-2014, 6:20 PM
NFR85's Avatar
Default Alpha Tag Error
I have 2 Uniden BCD996XT and I want to provide Alpha Tags to both. It's not giving me an option to use a com port. It click on the down arrow and it says "None". One the first scanner i'm using Front Mic/ Real Tec High Definition. And the second scanner I'm using Sound Blaster X-Fi
How do I address this issue so I can run Alpha Tags.
Thank You
Old 06-11-2014, 11:05 AM
mdulrich's Avatar
What software are you using to stream and do you have the data cable connected or just the audio cable?
Streaming the Allen County, Ohio Public Safety Scanner at http://www.broadcastify.com/listen/feed/188
Providing ADS-B data from NW Ohio for http://www.flightradar24.com
Old 06-11-2014, 11:35 AM
NFR85's Avatar
I'm using Scanner Cast.
I have a wire connected from scanner into the audio port.
Old 06-11-2014, 12:26 PM
That's your problem. The audio cord only sends the sound to the computer. In order for the scanner to transmit the alpha tag you need the serial/USB connection to the scanner's programming port as well.
Old 06-11-2014, 12:28 PM
NFR85's Avatar
Ok, thank you. Any recommendations on one?
Old 06-11-2014, 12:54 PM
eaf1956's Avatar
Post
If you have an RS 232 port on your computer just buy a standard (NULL) RS 232 cable and use the rear port on the scanner. If not you can use a USB to RS232 adapter and then a NULL cable. Another option is the USB 1 cable from UNIDEN to the front port. Or the Cable that came with the scanner to the front port (if you have RS 232 on computer) There are lots of different ways to do it.
Current scanners:BCD 996XT,BCD996P2
BCD536HP (2)
Ham Gear: Icom 7000, U82, V82, V8, IC 2820 and OMG a YAESU FTM400DR
Tags
alpha tags bcd996xt
