Hijacked live audio feed- Request for private message
KAA951
Kansas
Could someone responsible for coordinating the live audio feeds please send me a private message?
Apparently, the live audio feed I have been providing for a number of years has been "hijacked" to another provider without any complaints as to my feed, problem notification or dialog with RR. I hope that an error has been made, but I would rather not discuss this in an open forum.
Thanks!
KAA951
mikev
Northern VA
As long as the encoding software on your computer is still connecting to RR/Broadcastify servers, it's probably safe to say that there's no "hijacking" going on. Check the settings in your encoding software to make sure that it's still connecting to RR's servers. If you're using Scannercast for RR, then it will only connect to RR's servers and I don't believe it can be changed.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
If I understand correctly, another feed has popped up in the area which basically duplicates the OP's feed.
I believe if a feed offers something slightly different, it will be accepted even though the content offers what another feeder is already feeding.
frazpo
SW Mo
Same feed, different provider?
RR isn't strict on feeds being very similar. So if someone has created a feed with some of the same departments then I think your out of luck. If that is what is going on.
eaf1956
Evansville, IN
It wouldn't bother me if someone even duplicated my feed. If one went down people could listen to the other one or pick the one they like best.:wink:
frazpo
SW Mo
I agree. At times some competition is good. It will keep the quality and up time in the green.
Great backup in a case where an outage knocks one down. Redundancy.
KAA951
Kansas
Since no one from RR has contacted me, I guess I will have to air this in public.
I have been a long time RR (2004) member and live audio feed provider. My feed provides fire and EMS coverage in Topeka / Shawnee County Kansas. I have had no complaints as to the feed or my managment of the feed. Overall, the feed probably was up more than 95% of the time and worked through a dedicated PC.
I took the feed down for a few weeks for maintenance as the radio systems were in the midst of a change from analog to P-25 and I needed time to reprogram my receiver and get used ot the new system. I updated the feed message to indicate that it would be down for maintenance. Now, with no warning or ANY communications from RR- my feed has suddenly been swept off my accounty and is being provided by another member- who has only been on RR since December!
I have put a great amount of time and effort into providing a good audio feed- from updating and upgrading my equipment to installing an exterior antenna. I hope that someone has made a mistake in the assignment of this and that it can be worked out- but so far, no one from RR has responded.
Any advice on this would be appreciated.
mule1075
Washington Pennsylvania
Please do not take this the wrong way but you aired it out here first. You could have sent a pm to the live audio admin yourself and more than likely have got your questions answered and not put it out in the public forum.Also after a week or two as has been stated before and your feed is offline it gets deleted and you have to reapply.I think their is a live audio handbook with all the rules and options on the site.
mule1075
So in all reality your feed went offline for a bit and someone else stepped up and provided their own.
KAA951
Kansas
I attempted to PM several admins, but none had their PMs set up to take messages. I searched all over the site and wiki for a contact to no avail. I also looked specifically for any rules as to when a feed is cancelled, reassigned etc and could not find one. All I could find was the terms of what could be aired on a live feed.
Please, you would be helping if you could provide me with a PM to contact the live audio admin and/or point me to the rules that deal with how long a site is down before it is reassigned.
Regardless, I think it is poor that they reassigned my feed- same name and details that I wrote- to another user without even contacting me.
mule1075
kendrik578@broadcastify.com
mjbjr
Macon,Ga USA
Broadcasting Feeds - The RadioReference Wiki
Half way down you see the notifications sent while the feed is down.
Feed Notification Settings
Time Down Action
15 min Email Notification to Feed Owner
6 Hours Email Notification to Feed Owner
24 Hours Email Notification to Feed Owner
7 days Email Notification to Feed Owner
14 days Email notification and feed deactivated.
21 days Feed deleted.
eaf1956
Evansville, IN
Extended Feed down time
In the future try sending Richard a PM telling him that your feed will be down for an extended amount of time and it won't get deleted. I did this once or twice and all was well and good. Just putting on your feed status that it will be down doesn't notify RR. And I am sure if you contact him he will put your feed back on the system.
fredva
Virginia/West Virginia
I second that about sending Rich a PM when your feed is going to be down for awhile. There is also the Help tab on the feed management page where you can send the admins a message about your feed.
tk000
Central Ohio
As already pointed out, information regarding feed deletion after extended periods of offline time is readily available. The correct method for submitting a request of this nature would have been to use form on the Help tab under Manage My Feed.
richtidd
San Mateo, Ca
You have no active feeds under this user name.
You indicated you took your feed offline for maintenance.
We auto delete feeds when they are offline for 21 days.
We could have saved your feed if you had asked us to.
We approve feeds on a first come bases if there is no existing feed for the same agencies.
