What do you guys suggest for an audio cable from the scanner to the PC? I'm getting a lot of static on my feed and I believe it's related to my audio cable setup.
I don't use anything special. Paid less than $5 for mine. I have had a few that were bad quality, and I just simply switched it out for a different one.
I don't know what feed you are hosting, so I'm not sure what the static sounds like. However, you might check the volume level of your "line in" on the computer. I've found that some background noise can be introduced if the "line in" volume in Windows is turned up high. It's better to keep that volume relatively low and if more volume is needed on the broadcast, turn up the scanner volume.
I am no longer supplying to RR/Broadcastify, however have recently switched a couple of my feeds to an RTL-SDR, and am more than impressed at the audio quality.
