Originally Posted by otrip
Using "Scanner Radio" app on Android with Sprint I am "unable connect to audio server". Diagnostic mode it tells me: "Problem Detected" "Your carrier is intercepting the app's attempt to connect to Broadcastify.com's audio servers." This only happens when my phone is in 3g (Sprint) mode. When my phone is connected in wi-fi mode (through my router) it works fine.
Anyone else having this issue?
Are you running version 3.9.5 or later of "Scanner Radio"? Earlier versions of the app will falsely report that the connection is being intercepted due to a change that was made to one of Broadcastify's servers.
Can you run the app, then select "Diagnostics" from the menu again, and then select "Share" from the menu to send me (the developer of the app) the info? Once you've done so, send an e-mail to me at
support@gordonedwards.net letting me know and I'll take a look at what it reports.
Thanks,
Gordon
