Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify / Live Audio Listener Support
Broadcastify / Live Audio Listener Support - This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 02-24-2014, 9:20 AM
AC0RV's Avatar
Question Radio Feed software
Sorry did see the right forum to place this post in. So if the moderators would please move it to the right forum, it would be appreciated a lot, thanks
Ok I see there is a Unit ID look up is list in the program for the xt scanners and so forth. Does that mean it will display the unit IDs in Display on players that will accept the meta data to displayed ?
thanks
The only way into heaven is through Jesus.
David F AC0RV
Skywarn # M187201
Old 02-24-2014, 1:21 PM
ProScan's Avatar
thanks
Yes, the Unit ID numbers and/or Unit ID text tags will stream to media players supporting text tags. The Unit ID Text Tag Lookup file is for displaying Unit ID text tags longer then 16 characters so you may not need to use the lookup file.
For streaming the Unit ID number:
Put "%U" without quotes in the Custom Format box.
For streaming the Unit ID text tag:
Program a UID just like a TGID except prepend a lower case "i" to the UID just like an I-CALL is programmed. Prepend a "%" percent character to the Text Tag so RadioFeed can detect the UID Text Tag.
Put "%C" without quotes in the Custom Format box.
[EDIT] I errored when advising "Prepend a "%" percent character to the Text Tag so RadioFeed can detect the UID Text Tag. " That's not necessary when not using the lookup file.
Old 02-24-2014, 1:59 PM
AC0RV's Avatar
Smile
I thought so. Its too bad that I can not use that feature with 396t right now. But as soon as I get the 396XT fixed it will be placed. That is after I get one of the 436HPs.
thanks
David F AC0RV
Skywarn # M187201
