I know that this was posted about twice in early December but never appears to have been addressed.
Looking right now through various feeds, I consistently am directed to a script link
http://www.broadcastify.com/scripts/playlists/1/ (then the correct feed number and followed by) -5942299456
with various extensions based on feed type (see below)
This link loads a 1:21 audio clip regarding a dispatcher and officer talking about a report of a body part
Based on review of previous playlists for Broadcastify feeds which still work there is not a script reference in any of the file paths which I have saved in old playlists
For Example
Los Angeles (CA) County
LAPD Dispatch - Pacific Division - Windows Media Player
LAPD Dispatch - Pacific Division Live Audio Feed
The path I have for LAPD Dispatch - Pacific Division which still works correctly is
http://relay.broadcastify.com/170364276
LAPD - South Bureau - Winamp
http://www.broadcastify.com/scripts/playlists/1/20296/-5942299456.m3u
The path I have for LAPD South Bureau which still works correctly is
http://relay.broadcastify.com/143488007
Torrance Police and Fire Dispatch
http://www.broadcastify.com/scripts/playlists/1/20404/-5942299456.ram
The path I have for Torrance Police and Fire Dispatch which still works correctly is
http://relay.broadcastify.com/456636728
All of the links above that I tried tonight led to exactly the same audio file
This is just a small sample and is also true for many other feeds (if not all), at least all the ones I have tried for at least the last month.
At this point, at least for myself and some other members, listening to any feeds with any external media player has not been working (or possibly working intermittently) for nearly two months.
I have tried retrieving these links through both Chrome and Firefox and on multiple computers all with the exact same results
If possible, could an Admin with access to the site's protected files search for the http://www.broadcastify.com/scripts/playlists/1/
directory and see if there is a problem with the embedded links since they all seem to link to this directory
Thank you
For Example
Thank you
