Go Back   The Forums > Site Administration Forums > Broadcastify / Live Audio Listener Support
Broadcastify / Live Audio Listener Support - This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 03-13-2018, 7:54 AM
Default Connection Issues
I have been dealing with this for quit some time. I have switched router, I have worked on network issues, and can't seem to get reliable feed? I was thinking it might be ISP issues but proving that it seeming to be hard. Woke up this morning to it saying "Source Client - Broadcastify Timeout"?
*Scanning Macoupin County 24/7*
Old 03-13-2018, 9:00 AM
n0nhp's Avatar
There have been others with the same kind of problem. Here are some of the threads:
And there may be links to other older threads.
Read through and try running a ping-plotter type program for a while. There is a very good chance that your ISP is having dropouts with their connections that will not show up on TCP but kill the UDP that our audio uses.
Good Luck
Old 03-18-2018, 1:45 AM
flythunderbird's Avatar
I had a similar problem a couple of years ago. The cable company rolled a truck and the technician replaced the connectors in the house, which didn't fix it. I had previously run PingPlotter on it, so I gave the results to the technician ... he called his supervisor to discuss the PingPlotter results, and the supervisor told him to replace the connectors out on the pole. One of the connectors on the pole had gotten water in it, causing the disconnect issues.
"Yeah, I have some radios ... I listen to some stuff ..."
All information here is Copyright 2012 by LLC and Lindsay C. Blanton III.Ad Management by RedTyger
Copyright 2015 by LLC Privacy Policy  |  Terms and Conditions
