Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify / Live Audio Listener Support
Broadcastify / Live Audio Listener Support - This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 04-15-2018, 10:43 AM
Default Winamp error syncing to stream
In the last few days I can not get any feed to play in Winamp. I am aware of the links changing and have gone to the site like I have been in the last few weeks but now every feed I try Winamp says either "Error syncing to stream" or "Error syncing to mpeg".
The stream will work in the HTML5 player but that does not support alpha tags. I like Winamp because I have the text size for the playlist entry displaying 60pt text so that it is easy to read the alpha tags. Also Winamp is very light on resource use.
Thanks.
Old 04-15-2018, 12:11 PM
dave524's Avatar
same here, " error syncing to stream " on anything I try in Winamp
Old 04-15-2018, 12:23 PM
mule1075's Avatar
Working fine here. On multiple browser's and operating systems.
Uniden SDS100/780XLT Motorola HT1000/GM360 Whistler TRX-1
Old 04-16-2018, 12:56 AM
I have 4 systems here and they all do the same thing now. Last weekend they worked and now they do not and I have not changed anything on my end. What version of Winamp are you using and are you a premium subscriber? I can't think of anything else on my end changing to cause this.
Old 04-16-2018, 7:44 AM
mule1075's Avatar
Premium subscriber should not make a difference. I will check what version I am using and get back to you asap.
Old 04-16-2018, 8:16 AM
NYRHKY94's Avatar
FYI - I was receiving the same syncing to stream error as well this morning using WinAmp from the Broadcastify site drop down. A few minutes ago I tried it again and this time it connected. Not sure what changed? I'm using WinAmp version 5.666 (which I believe is the latest available).
BCD536HP/BCD436HP/BCD996P2/BCD325P2/BCD996XT/BCT15X/PRO-197/PSR-600
Old 04-16-2018, 8:21 AM
mule1075's Avatar
I am using version 5.666 build 3510 (x86)- Nov 25 2013.
Old 04-16-2018, 4:10 PM
Well Ill be... Finally had a reason to upgrade Winamp. Was running 2.x and 5.1x on several systems and 5.666 3516 is working fine now. Imagine that.
Thanks for the help.
Old 04-18-2018, 1:54 PM
dave524's Avatar
argh , guess my problem is running 5.61, when you upgraded did you have to do a complete new install or can you just download the 5.666 and overwrite the older version retaining your preferences and book marks etc.??
Old 04-19-2018, 8:59 PM
Thanks.
My winamp did the same thing. I upgraded to 5.666 this afternoon and all is fine now.
