Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify / Live Audio Listener Support
Broadcastify / Live Audio Listener Support - This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 04-27-2018, 3:26 PM
Default ScannerCast Windows 10 Notifications
Hello. I'm currently streaming 2 feeds from my organizations computer. The first one has been running no problem for months. We decided to do a second feed and, after some fiddling, got it working. BUT the second feed keeps popping up a notification
RR connection DOWN
The connection to audio1.broadcastify.com/(bunch of numbers and letters) has been lost. ScannerCast is trying to restore the connection.
THEN a matter of seconds later you get a pop up
RR connection is UP
The connection to audio1.broadcastify.com((bunch of numbers and letters) has been restored.
I've looked at the settings, and I can't see any differences, other than which feed is selected, between the two instances of ScannerCast, so I'm not sure why only one is displaying the continuous UP and DOWN notification. As far as I can tell, it's streaming the whole time. I've tried testing it when it says the feed is DOWN, and it streamed fine, but it changes so fast it's difficult to be sure I'm catching it during whatever is triggering the notification.
If anyone has any advice, I'd appreciate it.
Old 04-27-2018, 4:27 PM
flythunderbird's Avatar
Are both of your feeds going to the same Broadcastify server, i.e. audio1.broadcastify.com?
Is it dropping and reconnecting all the time or at (more or less) the same time every day?
Glenn
"Yeah, I have some radios ... I listen to some stuff ..."
Old 04-27-2018, 4:51 PM
The notifications were going non-stop, continuously.
I actually got it fixed though I think. I had to restart my computer, which of course restarted the programs, and when they ran I saw an error I'd never seen before. I can't remember the exact wording, but it was something about tags and com port if I remember right. I never messed with any of the tag settings, because I'm not using them and the first feed worked fine without me bothering with that stuff. But I stopped the feeds after the error, disabled the tag feature, and restarted it, and it's working fine. The notifications have stopped for about half an hour now.
Old 05-16-2018, 6:36 AM
Okay, apparently I was wrong. It's not fixed. the notification is popping up and down again and again. Is there any advice after all?
Old 05-17-2018, 4:54 PM
Are both feeds streaming to the same Broadcastify server?
Are you streaming it from your home or your workplace? If you're streaming it from work and it's going through a proxy server, weird things can happen (although you'd think it would affect both feeds).
Have you tried streaming it using RadioFeed rather than ScannerCast? I started out with ScannerCast and had issues ... switching to RadioFeed solved them. https://www.proscan.org/
Are you running AVG Antivirus? If so, disable it. AVG is known to cause problem with feeds. Even if you're running some other antivirus, disable it and see if that fixes it (although again, you'd think it would affect both feeds).
If switching to RadioFeed and disabling the antivirus software doesn't fix it, download PingPlotter and let it run for several hours. PingPlotter will show where drops are occuring along the path from your PC to the Broadcastify servers. There is no guarantee that both feeds follow the same path to the Broadcastify servers ...
Glenn
