Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify / Live Audio Listener Support
Broadcastify / Live Audio Listener Support - This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 08-09-2018, 2:45 AM
Default Feed is looping 10 second clip
I was listening to a feed and itís just repeating itself. Is there a way to report it as OFFLINE even if itís not technically offline itís just broken?
Old 08-09-2018, 7:55 AM
flythunderbird's Avatar
Click the 'Report a Problem' button on the feed page.
Glenn
"Yeah, I have some radios ... I listen to some stuff ..."
Live Long and Monitor!
Old 08-10-2018, 8:03 AM
richtidd's Avatar
Live Audio Administrator
Hi
Hope you are well today!
Welcome to Broadcastify.com Live Audio.
You can try these Windows apps:
https://broadcastify.zendesk.com/hc/...ile_site=false
Otherwise, there are a couple of things that may cause this with the web players:
1 In Windows OS, there's a Line-In properties window and it maybe set to play through two different channels. Shut one channel down and the echo should stop.
2 You maybe listening to the feed via the web or Java player.
If so, the looping or repeating, echo, re buffering or stopping, of the feed is a known bug with the web player & sometimes with WMP and the Java player as well.
What you are hearing is audio that was cached by the browser the last time you listened along with the current feed audio.
To avoid this problem, I listen to feeds with WinAmp or iTunes.
However, you can try clearing your browser cash.
To clear the Java Plug-in cache:
1.Click Start > Control Panel.
2.Double-click the Java icon in the control panel.
The Java Control Panel appears.
3.Click Settings under Temporary Internet Files.
The Temporary Files Settings dialog box appears.
4.Click Delete Files.
The Delete Temporary Files dialog box appears.
There are three options on this window to clear the cache.
1.Delete Files
2.View Applications
3.View Applets
5.Click OK on Delete Temporary Files window.
Note: This deletes all the Downloaded Applications and Applets from the cache.
6.Click OK on Temporary Files Settings window.
Note: If you want to delete a specific application and applet from the cache, click on View Application and View Applet options respectively.
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 08-12-2018, 4:27 AM
Exclamation
https://www.broadcastify.com/listen/feed/7893
Please listen to this one for me. I tried clearing caches but I only have mac os and ipad and iphone. I dont think it works because theyre all syncing data or it really is broken. I figured out how to report but it has been a couple days now and i bet others have reported because its has been doing this for like at least 9 days now. If you guys get the same result can you please report it too otherwise I'm going to figure out a different solution I guess if its on my end. I tried like 5 different apps, every device I have, html5, itunes, java, and flash; so, maybe the wmp and winamp ones might work I cant use them on mac
Thank you richtidd for your reply
Old 08-12-2018, 4:42 AM
Exclamation Santa Clara down or just me? Feed: "County Sheriff, Police, Fire, CHP, and CAL FIRE"
Does anyone know whats up with this feed? 0 listeners and doesn't work correctly for me, is it just me or is it messed up?
Old 08-12-2018, 1:45 PM
rcool101's Avatar
Not working here. Looping the same word over and over
HP-1E BCD536HP BCD436HP SDS100
Old 08-13-2018, 9:32 PM
Same problem here. I reported it to the feed owner; we'll see what happens.
Glenn
Old 08-14-2018, 3:12 AM
W8RMH's Avatar
I sent a problem report too, but it is still stuck in a loop.
Tags
feed problems, santa clara county
