Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify / Live Audio Listener Support
Broadcastify / Live Audio Listener Support - This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 11-04-2018, 8:56 PM
Stavro35's Avatar
Question MacOS Mojaave and Ladiocast
After updating to the latest MacOS . I can't get my scanner feed to work properly. I've been using Butt and Ladiocast. Butt, works fine, since the update to MacOS Mojave. Ladiiocast is not.Should I go back to the previous operating system? Or, is there an alternative combionation, or single software solution to get my scanner feed back online?
Primary scanner Whistler TRX 1 secondary Pro163,Pro 164 Pro106, BCD 436HP
Old 11-05-2018, 9:49 AM
Nicecast should work
Sent from my iPhone using Tapatalk Pro
Yes, there are stupid questions. Don't ask them.
Old 11-05-2018, 1:52 PM
ko6jw_2's Avatar
LadioCast is available in the App Store and should be compatible with Mohave otherwise Apple would not make it available. Developer licenses require all sellers to be compatible with new OS. I'm using a MacBook and the store says it will run on my computer. I run Broadcastify streams on iTunes. Seems to work fine although I rarely use it.
Try downloading LadioCast again from the App Store. There may be a new version.
Mohave has some neat new features. Don't go back.
Old 11-05-2018, 7:07 PM
Stavro35's Avatar
"Check the network environment or the connection configuration." is the error message I get. I've configured Ladiocast to the specifications. And the software "butt" actually connects. But Ladiocast still won't.
