Old 10-31-2011, 6:09 PM
squirrel911's Avatar
Location: Estill Springs/Decherd/Winchester/Franklin County Tennessee
Question Wouxun KG-UV3D 2meter/350-470 Transmit Issues
Ok, my wouxun was working perfectly and then all of a sudden it just quite transmitting audio. I can key up and open up the repeater but no audio will go through. I can recieve audio just cant transmit audio. Even with or without my shoulder mic. I called powerwerx.com where i got it from and they told me to send it back to them. I was hoping someone on here can help me with the issue first. Any suggestions??
Old 10-31-2011, 7:59 PM
Send it back. They'll probably give you a replacement radio. If the external microphone doesn't solve the problem than you've got an electronic problem on a circuit board and you don't want to mess with this kind of fault when your unit is under warranty, which I assume it still is.
Old 11-01-2011, 1:16 PM
It is. I talked to them and they said to send it in. They did ask me though if I used the Wouxun Commander software to program it. I asked why and they said that software will somehow fry the circuit board. how is that possible?? I did use that software but I have read nothing but good reviews on it.
Old 11-01-2011, 9:42 PM
RadioDitch's Avatar
The problem isn't actually with the software. The problem is when people leave the radio connected to the computer for too long. When connected for too long, heat is transferred via the cable and the radio gets very, very hot. As a result, damage is done to the circuitry. I've seen plenty of complaints and claims of damaged radios from it. It's a design flaw on Wouxun's end.
Constantly On The Road
Radios: Gratuitous Radio Inventory Here.
DC to Daylight, You Cannot Outrun The Radio.
Be a man. Drill it! Support Hams Against Magnetic Mounts.
Old 11-01-2011, 11:03 PM
I only had it pluged in once and that was to program it and it only stayed plugged in for maybe a minute. So I dont think that would be it unless it is that big of a flaw
Old 11-01-2011, 11:14 PM
RadioDitch's Avatar
No, it would definitely take longer than a moment. About 5-10mins on average. Sounds like you just have a defective radio.
Old 11-01-2011, 11:20 PM
I guess. Other than this issue I love these raiods. I got the UVD1P and the UV3D. Thanking about buying the new 6D version. I really cant wait till the mobile comes out.
Old 11-02-2011, 8:57 AM
. . . . When connected for too long, heat is transferred via the cable and the radio gets very, very hot.
In over 40 years in electronics, I have never heard such an outrageous statement, not even from people totally ignorant of electrical/electronics theory.
Comint
Old 11-02-2011, 9:50 AM
Skypilot007's Avatar
Comint
Right...probably some dewsign flaw in the USB or serial interface, which ever it uses.
Old 11-02-2011, 2:37 PM
Comint
I dont have that much experiance but I must agree with you.
Mine has never got hot and I have 2 radios and 2 cables.
Old 11-02-2011, 3:07 PM
RadioDitch's Avatar
Comint
I agree 10,000%. But that's Wouxun's explination. Sorry if it appeared as though I prevented it as fact. Wasn't meant to be. However that's also why I said, "complaints and *claims* of damaged radios from it".
Old 11-02-2011, 5:55 PM
loumaag's Avatar
Silent Key - Aug 2014
Let me make a comment here.
I think that there may be a bit of a language barrier thing going on here. I think that the Wouxun folks may have a hard time explaining why the heat is being generated; although, I can certainly understand how it could be done, so they said it is transferred by the cable.
And I guess technically that is correct, and before someone thinks I have gone around the corner in my old age, stop and think for a moment what voltages appear on a RS232 signal path. Nominally both a -12v and a +12v appear on on the port. A bad design of either (or both) the port on the radio and the software can cause those voltages to be constantly pulled (assuming the computer doesn't crash the driver). For short periods, that shouldn't cause problems, but based on my limited experience with SMD it doesn't take much heat to start causing havoc. Ah, for the good old days of wire components inside electronics. Oh wait, that was when stuff was expensive...never mind.
ETA: Well, someone sent me a message pointing out that the Wouxun cable incorporates a level converter to change the RS232 voltages to TTL voltages (~ +5v/0). I don't own one of these radios and really don't have a dog in this fight but I figured that I would pass on the information. Interestingly enough this would lead me to believe that the cable has a MAX232 type chip in it and if designed correctly should work. However, just something in the way the information was passed on makes me wonder if they designed this as a single ended TTL interface as opposed to a differential TTL interface. Without getting into the technical aspects, a single ended TTL requires current to be returned on the ground connection which has proven in the past to allow other common ground connected components to be affected. In any case the above is for consideration and information of those that might be interested.
Old 11-02-2011, 6:44 PM
OCO's Avatar
OCO OCO is offline
And I was just going to suggest wrapping the cable around an ice cube, while designing fan cooled heat sinks for it.... Possibly the engineers were using Google Translate??
"An opinion should be the result of thought, not a substitute for it." - Jef Mallett
. Heathkit CR-1
Old 11-02-2011, 7:22 PM
radninja88's Avatar
Sounds a bit plausible. My 1p's speaker crapped out on me. Now, I am only able to hear audio through a speakermic.
Still an awesomely cheap radio.
Just another cot jockey.... I mean EMT.
BC355c - BC15X - Cobra Classic - HT1000 - Wouxon - Realistic Shortwave
Old 11-04-2011, 10:57 AM
loumaag's Avatar
I added some information to my post above.
Old 12-13-2012, 9:09 PM
Comint
It doesn't sound right and maybe what he meant was that something in the HT gets hot while it is connected, but I agree the heat certainly isn't conducted down the cable.
Hopefully just a bad choice of words.
