Old 01-16-2013, 10:52 PM
Wheels47130's Avatar
Default UV2D and getting manual when programmed?
Ok, I have a Wouxun UV2d that a friend programmed the local repeaters in. Now how can I switch back to manual search and just turn my dial and check all frequencies?
Thanks if you can help!
Timothy Agee /KK4NPQ
Wouxun UV2D
Radio Shack Pro-164
Daytona Beach, Florida
Old 01-16-2013, 11:08 PM
sparks40's Avatar
The bad news is....You don't. The Wouxun HT's don't have a VFO, so you're limited to whatever frequencies are programmed into them. Study your manual, and practice the basic menu operations to become familiar with them.
The programming software is also a HUGE help, but it's to your advantage to know how to perform the basics unless you have a laptop to drag around with you to change the memories.
If this is your first HT, you would have been better off spending the extra money and getting something like a Yaesu FT-60.
Old 01-16-2013, 11:32 PM
Basically, got to 'freq' mode and start twisting that knob. That varies the VFO which this HT does have.
- 'Doc
Old 01-17-2013, 8:13 PM
wow...
Tim,
Press the orange MENU key, then the green TDR key. This toggles the radio between "Channel Mode" (memory presets) and "Frequency Mode" (VFO tuning). I think you made a fine purchase, but I own many Wouxuns. :-)
Old 01-20-2013, 8:30 PM
Default Thx
Thanks so much for the help. I knew it was just a setting,, just couldn't figure out that manual
73s
Wouxun UV2D
Radio Shack Pro-164
Old 01-23-2013, 9:23 AM
sparks40's Avatar
I stand corrected...I have an older UVD1, and the manual that I got with it sucks. I always heard there was no VFO on the Wouxuns. They are decent radios. Apologies all around....
Old 01-23-2013, 9:33 AM
62Truck's Avatar
I can go to freq mode on my 1D that is just like a VFO
Lions, Tigers, Bears....
