Baofeng 888-S
fdscan
New York
Well, I got outbid on yet another radio on eBay. I'm curious about these... 2 Two Way Radios BAOFENG UHF Handheld Interphone Transceiver 2 Way Walkie Talkie | eBay
I know they're Chinese and probably crap quality... But I have heard some good things about them in the midst of all my allegations about them being complete Chinese crap.
I'm curious what you guys think of this, because I don't know that much about them. They are pretty cheap... 50 bucks... Including software and programming cable. I'm going to be using them to probably half monitor local FD/PD, and I'll fill the other half up with more FD/EMS or probably GMRS, but I can change it around because that software's included. They aren't going to be dealing with any severe duty work or anything, I just want to know if anyone has experience and feedback.
Richmond, VA
No experience with those in particular, but if the software is anything like the baofeng software that comes with the uv5r plus, forget about it. The software doesn't work for squat. I don't know if there are any 3rd party programs that work with that model but I'd check before purchasing them if I was you.
Sent from my cm_tenderloin
RonnieUSA
Rowan County,KY (Morehead)
Why would You want something that can only transmit about 6km,about 6500 yards?
According to the listing You can buy it for $48.99.
fdscan
New York
This is the software that comes with it: Uso del software per programmare le radio Bf-888 Baofeng - YouTube
Video's not in English but it still shows the software.
RonnieUSA - I didn't see that, actually... But, whatever I transmit will be in the area on GMRS non-repeater will be in the area of one square mile, at the most. It would still be nice to have a better distance than that, though. All the FD and PD in my town runs off of four repeaters throughout the town, and the EMS is AMR/CMED, which has a repeater out of the city next to me, not sure if I'll pick it up or not, but I'd assume so. Scanner picks it up just fine.
RonnieUSA
Here yea go dual band, and cheaper also >> BAOFENG UV 5RA Ham Two Way Radio 136 174 400 480 MHz Dual Band DTMF CTCSS DCS FM | eBay
Will do what You want it to.
fdscan
New York
I was considering it, but I want something small and simple, and might need two as well. That's one of the main reasons I looked at the 888S.
fdscan
New York
I don't know, cheap chinese crap for 90 bucks... And to be completely honest with you, I absolutely have the design and look of it.
fdscan
New York
Don't take it wrong man, I didn't mean that in a negative way. Of course I appreciate the help, and I know that both are Chinese crap. There's just a good price difference between the two, and I doubt I'll use all of the features on the one you posted, but thanks for the suggestion on it.
RonnieUSA
I'm not offended, You go from 1 band to 2 bands, that was what I was looking at.
fdscan
New York
I appreciate the suggestions, but I just don't have a need for the more sophisticated ones people were suggesting, and I personally didn't like the looks of them at all.
I'm just curious about what people think about the 888S, if they're worth buying or not.
KC2SUR
Central VA.
Re: Baofeng 888-S 16 Channel UHF Tranceiver
I own three of these radios, and I have nothing but good things to say about them.
Easily programmed via PC, Great audio on Tx/Rx, adequate range, and great battery life.
I use them for 70 cm (440 MHz) Amateur use, and to MONITOR my local public service frequencies, and have no complaints on either !.
I have no trouble hitting ham repeaters 20-30 miles away, and have gotten great audio reports on both local simplex and repeater Amateur use.
In my humble opinion,
this is NOT ..."cheap Chinese crap"... at all, but it is a well functioning radio that is well worth its price !!!
If I had to pick one thing negative to say, it would be the lightweight case, but I have never made it a habit of dropping my radios, so that will not be a problem.
So, I say go for it !!!
de:
fdscan
New York
I use them for 70 cm Amateur use, and to monitor my local public service frequencies, and have no complaints on either !.
I have no trouble hitting ham repeaters 20-30 miles away, and have gotten great audio reports .on both simplex and repeater use.
In my humble opinion, this is NOT ..."cheap Chinese crap"... at all, but it is a well functioning radio that is well worth its price !!!
de:
Thanks for the information, I appreciate it.
You're saying the casing/housing of the radio itself is lightweight?
KC2SUR
Central VA.
You're welcome.
Its basically the same non-waterproof plastic case as in your average GMRS/FRS radio.
Just don't expect a heavy/hard case Like on a Vertex, Kenwood or Motorola Commercial Rig.
But Just as long as you don't drop or drown it, it should be fine.
jaspence
Michigan
Baofeng radio
I know this has been said before, but just buying two radios and picking a frequency can cause problems and bring big fines. If you do not have a license for the the frequency and just pick one, you may interfere with medical, fire, or police. Operating on any UHF frequency without a license except FRS is illegal, and even FRS requires a radio that meets FCC certfication
KC2SUR
Central VA.
Correct !!!
I would have thought that there were UHF equivalents to the "MURS" channels,
but upon checking, I see that even the "Color Dot/Star" frequencies require a license !!!
Thanks Jaspence,
I learned a useful tidbit of radio information today !!!
