Old 07-23-2013, 8:32 PM
searingxheretic's Avatar
Default Baofeng uv-5r plus antennas
I was looking at the newer Baofeng UV-5r plus models ( the color models; yellow, red, blue, and camo ) and noticed that the color model has a longer antenna than the original black edition. Does anyone have any experience with the 18cm antenna on the color models, is there any discernible difference in reception?
Sent from my cm_tenderloin
Have extra CPU resources for your computers that are running 24/7 anyway?
Join me at World Community Grid, team RadioReference.com, to put those resources to good use!
Join World Community Grid!
Old 07-30-2013, 7:13 AM
Baofeng uv5r testing antennas - YouTube
Not sure there is much discernable difference in this test. Big antennas for a small radio though. Mine seems to do just fine on the RX.
Old 07-30-2013, 10:33 AM
xeno194's Avatar
Antenna expert i am not but i replaced all my import radios with these newer antennas from Baofeng
Review
Replacing original UV-5R antennas | Ham Radio Blog PD0AC
Purchased from
Qriginal BAOFENG Dual Band Antenna for UV5R Plus UV5RA Plus UV5RC UV5RD A076 | eBay
RSP 1&2*SW-2 & SPF-08*Afedri .Net v3*Airspy Mini*RTL v3*BR-330T*MD-380*UV-9D*UV-82*UV-6R*UV-5R*PL-310et*gp5-ssb*CR-1a*450D
SDRplay FB Group
Old 07-30-2013, 6:36 PM
Default Re: Baofeng uv-5r plus antennas
The antenna on the eBay page is 15cm. The antennas on the new 5r+ qualette series (color radios) are 18cm. I have yet to find one of the 18cm on sale by itself (without the radio).
Old 10-07-2013, 9:08 AM
K3NXU's Avatar
A very popular antenna is the NA-771.
Better performance on VHF, somewhat better on UHF. Although it is 14.5" long.
Keep in mind, there is no Magic Antenna out there :-)
John K3NXU
UV-5R Information Site http://www.miklor.com/uv5r
Old 10-07-2013, 6:10 PM
I use a Diamond SRJ77CA with some pretty good results. No adapters needed either.
Old 10-07-2013, 6:39 PM
jeepinjeepin's Avatar
Has anyone noticed increased static/noise when using longer, or more specifically 1/4 or 5/8 wave base or mag mount antennas?
I have a Nagoya NA-701 antenna on mine that I feel works better than the stock antenna but compromises on length. I may try one of the longer versions later. I also made a simple 1/4 wave whip antenna for a mag mount that seems to pick up lots of static bursts.
Josh
NC4WD
