Old 07-28-2013, 7:10 PM
Steveradio's Avatar
Default Baofeng UVB6 Dual Band Question
BAOFENG UV B6 Dual Band VHF and UHF 5W Walkie Talkie 2013 Newest | eBay
I already have the Wouxun KG-UV6D and love using it the only issue have is it stops scanning when any signal is received even with the Receive PL tone ON. Just curious if anyone played with this model and experience the same issue before go purchase another?
http://lvcomm.proboards33.com/index.cgi
Scanning Lehigh Valley, Pa. North of Philadelphia
Old 07-28-2013, 8:36 PM
From what I have read that appears to be a "feature" common to all Baofeng and Wouxun models and clones that use the same processor.
Tom
Old 07-28-2013, 9:19 PM
Steveradio's Avatar
That's what kinda figured thanks
Old 07-28-2013, 11:32 PM
robertmac's Avatar
Can't comment on the Baofeng, but my wouxun doesn't stop provided it is set up correctly. wouxun shows it as T-CTC and R-CTC so I only input the CTC for the wouxun to transmit it. Besides, the scan rate of the wouxun is silly slow so seldom if ever scan with it.
Old 07-29-2013, 3:36 PM
Steveradio's Avatar
Thanks for the tip. i know there are more features on my Wouxon have not played with much yet.yes when you have 70 channels programed its a slow scan
Old 07-29-2013, 6:09 PM
mancow's Avatar
It seems they wrote one version of the code and every other radio has been based on it.
Old 08-02-2013, 4:40 PM
Post Baofeng
I've heard these Baofeng radios on the air and between me and you,they need better transmit audio!
TYT is el cheapo also ,if any of you were thinking about a Baofeng,I would rethink it.The TYT radios look,feel and work alot better than the Wouxuns or the Baofeng.I have a TYT TH-UVF6 and it almost seems like a copy of a Kenwood Th-F6 inside and how it sounds.Loud and clear!
The TYT radios accept Baofeng batteries too and chargers.
http://www.youtube.com/watch?v=i6VQsTgTL-s
Theres a 144/220
a 220/440 <i have a few
and a 144/440MHZ
Old 08-02-2013, 8:21 PM
Steveradio's Avatar
Does the TYT take Alpha Display like say TAC 1 instead of frequency read out
Old 08-06-2013, 8:37 AM
grem467's Avatar
TYT TH-UVF9 Dual Band Radio 136-174/400-470Mhz - YouTube
Theres a 144/220
and a 144/440MHZ
Do you have any performance issues on your 220/440s? I owned one when they first came out and had to return it due to sensitivity issues. Very hit or miss on RX especially on UHF. I was hoping they would fix it some day as 220/440 is a combo that works well for me.
Old 08-06-2013, 10:05 AM
For those intending to use this and other Chinese radios on Part 90 frequencies, a little research is in order. Below are two items relating to TYT in particular. Number 1 is taken from the FCC OET Equipment Authorization site. Number two is part of an email I received from TYT Electronics pursuant to an email I sent them containing several questions including FCC certification. Notable is the absence of both the UV F9 and the UV F6. For those interested in checking FCC cert, go the OET site and put in the Grantee code (first digits of the FCC ID) in the Grantee box and then scroll down to the bottom and click search and the system will bring up all radios certified by under that Grantee code (TYT = x24, Wouxun=wvt, Baofeng=zp5).
1) EQUIPMENT AUTHORIZATION is hereby issued to the named GRANTEE, and is VALID ONLY for the equipment identified hereon for use under the Commission's Rules and Regulations listed below.
FCC IDENTIFIER: X24-THUV
Name of Grantee: Quanzhou TYT Electronics Co., Ltd.
Equipment Class: Licensed Non-Broadcast Transmitter Held to Face
Notes: Handheld Two way Radio; Model: TH-UVF1, TH-UVF2, TH-UVF3, TH-F5, TH-F8
2) From: vicky085@hotmail.com
To: ...............@hotmail.com
Subject: RE: TYT TH-UVF9 dual-band portable radio
Date: Fri, 17 May 2013 09:53:21 +0800
Hi Mike,
We have FCC for TH-UVF1, TH-9000, we sent TH-UVF9 for FCC testing. But it cost a long time, still do not offer us a report for these two radio.
Some of our customer in the USA and Canada still buy them without FCC report.
Old 08-18-2013, 3:34 PM
how did you get it too scann the channel ive read and read dont see how too get it too scann the memory chans any help would be mucho good thanks
BCD396XT,BCD436HP, BaoFeng BF-F8+ 2nd Gen UV-5R Dual-Band TRX-1 TRX-2 Bcd536hp Bcd996p2 Midlind-Gxt Retevis-Rt3 Galaxy-Cb-Base-Station-Dx-2547
Old 08-25-2013, 8:08 AM
Steveradio's Avatar
Did anyone have luck programing this unit. not easy to figure out and not too many how too videos if anyone has good link feel free PM me.
Old 08-25-2013, 8:19 AM
N4CA's Avatar
Of course, the easy way is to get a programming cable and use software (Baofeng or CHIRP). But if you want to manually program, here's a guide:
http://www.miklor.com/UVB5/UVB5-ProgMem.php
That site has a lot of other good information as well.
Sent from my Transformer Prime TF201 using Tapatalk 4
Old 08-25-2013, 8:22 AM
disregard
Tom
Old 08-28-2013, 1:17 AM
You can also get the programming software for the Baofeng at the 409shop.com online, it's a free download.
I have the Baofeng UV B5 same radio no flashlight on it. I prefer the Baofeng program over the Chirp it has more options.
I also own 6 of the Chinese ht's and 1 Kenwood TH F6A, and out of all the ht's I have the Puxing UV 973 is the best. It's a true dual receiver, better sensitivity on the front end than the Kenwood, scans faster than all the others I own, has a loud transmit audio and the receiver sensitivity is amazing, I put the Puxing next to the Kenwood several times and the Puxing hears signals the Kenwood doesn't know are there. The Puxing is simply one of the best Chinese ht's out there and very few people even know about them.
Your Baofeng is very easy to manually program once you learn how to input the frequency and save it to the memory number you choose.
