Old 08-20-2013, 12:30 PM
Default UV-5R transmit range
Hello all. I do not remember where i read this, but i was browsing around the other night and came across someone saying the Baofeng UV-5R will NOT transmit out of its HAM bands. I was under the impression that it transmits on every frequency it receives. Can anyone (with personal experience) confirm or deny if this radio transmits ONLY in the HAM bands?
Old 08-20-2013, 12:39 PM
There are several versions of the UV-5R. Some versions might only transmit in the ham bands if the vendor ordered them that way. You might be able to find more information at Baofeng UV-5R UV-B5 UV-82 Information Site
Tom
Old 08-20-2013, 1:15 PM
KF5YBZ's Avatar
I just got mine a week or so ago and I am not certified but I know mine broadcasts at 482MHz so... Can check others in a couple hours if you like.
Old 08-20-2013, 1:21 PM
robertmac's Avatar
With 4 or 5 watts output, transmit range would be line of site. But from 1 hand held to another not through a repeater, it would be about 2 miles max in a town, and maybe 5 miles in the country. On a mountain top it could be 100-200 miles.
Old 08-20-2013, 1:32 PM
WB4CS's Avatar
How does someone know that their radio will transmit on 482 MHz which is UHF TV Channel 16? Surely you didn't try it?
You're new here, just a friendly note, be prepared to be flamed if you admit that you're transmitting in places without being "certified" (licensed.)
To the OP:
If you're looking for a Boo-Fang that does transmit outside of the amateur bands in the US, be sure to get a model that has FCC Part 90 certification. From what I've read, some models have the certification and others don't. I believe they are the same radio internally, but would probably be a good idea to have one with an FCC Part 90 sticker on it just to be safe.
Brandon, WB4CS
Kenwood TM-V71A, TM-281A, TH-K20A. Yaesu FT-60R
Amateur radio is a hobby. We supplement emergency communications, not replace them.
Old 08-20-2013, 1:35 PM
KF5YBZ's Avatar
Yah I know... All I did was hit the key on the Baofeng and my scanner got instant feedback. No hijinks. But feel free to flame away...
EDIT: Just checked and mine does indeed have the FCC 90 sticker.
Old 08-20-2013, 8:35 PM
I owned a UV-5R for a short time, it was Part 90, & it would transmit out of the ham bands.
The best I ever got out of my UV-5R with the factory rubber duck was when it reached our club 2 meter repeater in Daisy, OK from Stuart, OK at a distance of 30.32 miles from my QTH to the repeater antenna when propagation was good. It's all about conditions. I was quite impressed.
Visit my local club online!
http://w5cuq.com/
Old 08-20-2013, 8:51 PM
Could have been into a dummy load (and to MT, the term "dummy load" is not a slam on you, it is a device used to allow a transmitter to be tested without radiating, much, into space)
T!
Old 08-21-2013, 12:44 AM
I can confirm the 5Rs (at least the "original" 5R) sold by "Sain Store" on Amazon are most certainly capable of "out-of-band" transmission.
F.Y.I., the stubby little 3" rubber ducky aerial that comes packed in with the 5R is, more or less, a dummy load. ;o)
4CS, it's pronounced "bo-FUNG". It's one of those weird Chinese vowel sounds. Think of the first syllable of "feng shui".
Old 08-21-2013, 7:07 AM
SpectreOZ's Avatar
The UV-5R can be software locked to a specific frequency range, this is how entry level amateurs are using them down here legally.
Essentially they are capable of 136-174 / 400-520 MHz unless configured otherwise (although some reportedly max out at 480Mhz)
"No matter where you go, there you are..."
Old 08-25-2013, 2:05 PM
DJ11DLN's Avatar
My F.D. recently bought a few UV-5R's as emergency backups for our Kenwood hand-helds and they definitely transmit on VHF-Hi. Also progged a local city department's tac on UHF in and they work there too. Not bad little radios when you consider the price. One of our guys got a Woxun extended range dual-band antenna (for something like $8) and put on his, it made a huge difference but it's like 15" long, too bulky for service use IMHO.
Old 08-25-2013, 5:21 PM
To the OP:
What he said !!!! They have closer to 3 watts of power, even at $45.00, not worth a plugged nickel. Good luck finding one with a FCC sticker. Most do not have them.
John
A man with a Gun is a citizen
A man without a Gun is a subject
