Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Budget and Entry Level Transceivers
Budget and Entry Level Transceivers For discussion of budget or entry level radios such as Baofeng, Wouxun, Puxing and other radio communications designated as commercial but not targeted for Amateur or GMRS. Also included are MURS and ISM 900MHz designed radios.
Old 10-04-2013, 4:12 AM
wm8s's Avatar
Default Powerwerx DB-750X group created
For your information-swapping pleasure:
groups.yahoo.com/neo/groups/db750x/conversations/messages
[I couldn't find one already. I am aware of the Anytone groups; if I missed the DB-750X group, please let me know so I can delete this one.]
Old 10-05-2013, 9:08 AM
Mikado's Avatar
Thanks, I'm thinking about buying one of these. So I joined the group to see what others have to say.
KD8VOK
WQPE868
Old 10-29-2013, 9:01 PM
Default Feedback
I guess I'll bump this thread.
$300 bucks plus programming
Looks like a solid radio
Anyone get their hands on one yet??
Kmacinct....
Old 10-29-2013, 10:19 PM
wm8s's Avatar
Yes. After many sputters from the software developer on getting Import to work, it seems to work fine now. I haven't had a chance to use the radio much, but it, too, seems to work fine. Several annoyances have already been reported (e.g., the nasty sounding beep when you use the mic's Up or Down buttons).
If anything develops, I'll report here and on the Yahoo! group.
...R
Old 12-13-2013, 5:02 PM
badge64's Avatar
ordered one standby for results
Old 01-18-2014, 2:31 PM
The_B_Chief's Avatar
Any new info on these rigs?
Also I keep seeing a different UHF split listed for this model. Some indicate that's 400-490 and others show it up to 512.
Can anyone confirm the actual range? And by confirm I mean someone that has actually had the radio in front of them. Actually touched or played with it.
I have some stuff....
Old 01-18-2014, 2:38 PM
wm8s's Avatar
If you haven't yet, join the Yahoo! group.
Mine goes to 490, which is too bad, since just another 4 MHz would have let it operate on the 490 MHz expansion band here in Houston.
Old 01-18-2014, 2:43 PM
Thanks.
I will check into the group. I really need coverage(for now) up to 512.
My head hurts trying to compare all these different radios and none of them seem to list the same specs on what appears to be the same exact radios. And now Wouxun has this quad bander out....
Old 01-27-2014, 4:27 PM
"And now Wouxun have this quad-bander out."
Please enlighten us...
Old 01-27-2014, 5:17 PM
http://wouxun.com/Two-Way-Radio/KG-UV950P.htm
Tom
Old 02-02-2014, 8:08 AM
Default wouxun kg uv950p quad band mobile radio.
i got one of these radios for christmas and have to say i am very happy with it. my only complaint is the uhf side only goes up to 479.995 which sucks is if i go to nyc and try to monitor some of the tac freqs that are on 485.000 and above i have to use my portable. but other then that everything else seems to fit the needs that i have.
