Old 10-06-2013, 9:03 PM
markandjere's Avatar
Red face Trisquare eXRS question
Mods , please relocate if posted incorrectly in this area. I just discovered recently that a local "security" outfit is using these radios. I read on the forums that they area hard to monitor but can be done effectively if you have the means. Which I don't . I was wondering if one would come accross one of these radios you can't just turn it on and listen in.... you would probably have to know / enter info that the other radios are set up ith to follow the traffic . Basically all the radios need to be set up the same to follow each other?
PRO-53 , BEARCAT III , BEARCAT 145XL , BEARCAT 147XLT , BC92XLT , REGENCY INF 50 , PRO-46 , PRO-74 , PRO-2042 , PRO-2050 , PRO-2018 , PRO-89 , PRO-96(X2) , GRE PSR800
Old 10-06-2013, 11:22 PM
rjk_165's Avatar
The radios you are referring to use are a little more high-tech than your average bubble pack GMRS.
Basically, they are digital and operate in the 900 MHz ISM band, and use frequency-hopping technology so that they can't be picked up by a scanner. Not sure if anyone's managed to do it, it's beyond my scope of knowledge.
I would assume you could purchase one of the radios and punch in the security company's channel/codes, but I don't own one so don't quote me on that. Not to mention, I don't know how you'd get that info.
Old 10-08-2013, 2:04 PM
Budget and entry level radio forum has been set up for non GMRS radios and additional information about these radios is listed there.
Licensed GMRS user
Licensed Amateur operator
Old 10-08-2013, 4:02 PM
Wirelessly posted (Opera/9.80 (BREW; Opera Mini/6.0.3/27.2338; U; en) Presto/2.8.119 320X240 LG VN530)
The TriSquare eXRS radios are analog frequency hopping spread spectrum radios, not digital. (The Motorola DTRS radios are digital FHSS, and work in the same 902-928 MHz range, but are not compatible.) There's a youtube video showing how someone was able to intercept the TriSquare analog FM signal with a spectrum analyzer or somesuch.
Short of expensive test equipment, you would need to know what numeric code they are using in their radios, and program the same into your radio(s), in order to follow their conversations.
Old 10-09-2013, 7:09 AM
Looks like no one reads anymore and tries to keep things going in the inappropriate forums...SMH
Licensed GMRS user
Old 10-09-2013, 3:01 PM
rjk_165's Avatar
Actually, it looks more like some individuals are more concerned with helping the OP as much as possible and answering his question than where the thread is posted.
I understand your concern that this isn't posted in the right forum (well, it has been moved now) but all that is really necessary on your part is clicking the "report" button and letting the moderators know where to move the thread; that is, unless you wish to contribute something helpful to it.
Please have some respect.
Old 10-09-2013, 9:22 PM
From my understanding, you need a near field receiver/scanner, a higher end set up, not low priced. You need to be somewhat close to the radio. The radio's are not digital, although parts of them may be, when out of range, they just cut off, no static.
For the radios to communicate with each other, the same code, one of two codes (one is a number code, the other is whatever name you give your radio, so you have one numbers which is the code, the other is letters, but you have to know both for the radios to talk to each other) that has to be put in every radio. Once that is done, you can talk to one person only or the entire group of radios that have the same code. You can also send short text messages. They even have built in text such as "Can't talk now" and 5 or 10 other things if you are looking to be 100% quiet.
They are really neat radio's. I was sorry to see the company that made them go out of business.
Mine transmit about as far as GMRS radios, sometimes not as far, much depends on what's around you.
Some people say they sometimes lose sinc with each other, but it has not been a problem for me.
What I find that is so neat is that you can talk to others, and not hear anyone else. You can have 1000 of the Trisquare radios right next to each other and 10,000 bubble pack radios and not have any interaction between them or other radios. It's not like going to a big event and having people all over the channels of the bubble pack radios.
Lastly, lets face it, how many people are going to have the necessary equipment, and if they do, bother to get close enough to you to monitor what you are saying. If your some foreign agent and some 3 letter agency wants to hear you, they could easily do so, but in real life, you will be able to talk to others without anyone else hearing what you are saying. I'd say you have a 99.9% chance of no one hearing what you are saying.
There are still Motorola radios that are similar as to the voice scramble, but you sure could not buy them for $80.00 a pair with batteries, chargers, and earphones. I wish another company would slightly improve the original design of the Trisquare and start making them again for about $120.00 a pair. I'd buy more. I'm just glad I got some while they were still available. I take good care of them and they work fantastic within their design parameters. Plus, they are kinda cool.
73's John
A man with a Gun is a citizen
A man without a Gun is a subject
Old 10-09-2013, 10:20 PM
rjk_165's Avatar
Those Moto's you're thinking of are the DTR series. Same idea, not sure if they're digital or not. Unfortunately they're not compatible.
But as you mentioned... Yeah, they're pricey!!!
Old 10-14-2013, 1:27 AM
mformby's Avatar
The Trisquare radios are no longer made. I have 2 TSX100 and wanted more but can't find them. That's a shame because I liked them better than my FRS radios.
Old 10-14-2013, 2:30 PM
Please accept my apology spd640 and thank you rjk_165......... I did a quick search for trisquare but did not see what I was looking for so I took a shot and posted here.
Old 10-17-2013, 6:06 PM
No need for any apology on my part,you did nothing wrong sir I was just letting you know about this forum,I just said to much and it was taken the wrong way and cost me some off time.
Licensed GMRS user
