wasabi4ever
Hello forum,
I'm new to the ham radio community and this is my first post and first question, hopefully someone can help with my issue.
I purchased a pair of Baofeng UV-5RE Plus online and they both came pre-programmed with a bunch of channels. I added a few more of my own and tested them out.
After a few weeks I decided to reset the radio using the function 40 RESET ALL.
After resetting it I can no longer program in certain frequency range using CHIRP, I'm getting an error "frequency xxx.xxxxxx is out of supported range" but program manually on the radio by keying it in is fine.
The weird thing was these were the same frequencies that I had on the radio prior to the reset and I was able to use CHIRP to program them in just fine before.
Prior to the reset I also downloaded and saved the image of the radio but after I reset it I cannot upload it back into the radio, I'm getting an error "image not supported by radio".
Have anyone came across this issue before and please advise me on how to fix it.
Thank you in advance.
