To anyone looking to acquire commercial radio programming software:
I have a baofeng uv5re HT and love it so far , I'm going to be getting an extended battery and larger antenna with 10 watt rating , anyone know of a way to get more than 5 watt tx on this radio ?
Unless you plan on making that radio put out 25W or more you are wasting your time trying to get more power out. You will gain more with a better antenna than trying to put more power out.
Read the article below to see how much you gain. A 3db gain is needed to require a noticeable change in signal strength, and to gain that 3 db, you must double output power.
My advice, don't even think about it any more. Just because the antenna is rated for 10 watts doesn't mean you have to put 10 watts into it. The radio isn't designed to transmit that much power and will lead to premature failure of the components. The advantage is so negligible that the risk far outweighs it.
I believe it's 6-VHF, 5-UHF and 3 for 700-950. My issued XTS2500 is set for 5 watts on UHF, and the radio guy is a stickler for rules, so that's what I'm basing it on.
If you are listening from the house and just wanted something with a little more gain to pick up more distant stations you could build a homebrew vertical dipole, or a dual band J pole for around a $50 investment to build the two. That does not include the transmission line or something to get it up off the ground so it is really worth while, but it is possible to do I have both and they help quite a bit when on the HT. I am able to hit a repeater that is 19 air miles from my house, but I am up on a slight hill with direct line of sight to the repeater. I have a 28' painters pole I use to get mine up in the air and the bonus is that it is portable.
