  #21 (permalink)
Old 12-07-2016, 3:40 PM
Default Tytera announces new mobile DMR radio.
Still learning a lot about radios, but would this be capable of monitoring DMR systems like what CareFlite and PHI use here and North Texas and conventional systems like Dallas Fire-Rescue and Dallas Police like my BCD436? Looking for a second inexpensive radio besides a Baofeng uv 82wp (only capable of conventional, so would only pick up DPD and DPD) to monitor those systems at home till I can get the 536 or another 436.
Chase
BCD436HP + DMR Upgrade + EDACS ProVoice Upgrade + ProScan
Baofeng UV-82WP // TYT MD-2017
Comet DS150S 25-1500 MHz Discone + Comet HS-05 M/J-SMA/P 0.5m
  #22 (permalink)
Old 12-07-2016, 3:50 PM
Any answer would only be speculation, as the radio does not exist yet.
FORMERLY MOONBOOTS
  #23 (permalink)
Old 12-07-2016, 5:54 PM
At this rate, it may never be available...
...well, maybe 4th Quarter of 2017 at the earliest!
Bill
N4GIX - Ham / WQWU626 - GMRS
VV-898, TK-840(N), 2xTYT-7800, 2xUV5R v2+, HP1, BCD436HP, TMV7A, Ritron RRX-450 Repeater, MD-380, XPR7550, 2xCS800, Bridgecom BCR-40U Repeater, Elecraft KX3 + PX3
  #24 (permalink)
Old 06-10-2017, 8:08 AM
eaf1956's Avatar
Post MD 9600 Price
Originally Posted by Thunderknight View Post
As a pre-order though.
While at first they were both at $219.99 now the UHF version is $339.99
Current scanners:BCD 996XT,BCD996P2
BCD536HP (2)
Ham Gear: Icom 7000, U82, V82, V8, IC 2820, MD2017, Vertex Standard EVX 539, MD 9600 and a YAESU FTM400DR
  #25 (permalink)
Old 06-10-2017, 5:48 PM
Ghstwolf62's Avatar
I posted in the other thread. It looks like its going to be a dual band radio. I posted a clip of it operating and it was definitely dual band with both freqs from both band displayed and the operator switching from one to the other and transmitting on both.
The dealer said it went up most likely because it was going from single band to dual band.
KJ4KFW
One of the few in the world apparently with radios & scanners that actually work like they're supposed to.
  #26 (permalink)
Old 06-10-2017, 7:47 PM
Default MD-380 External Antenna Question
Looking to use my MD-380 in a mobile environment. I don't want to use a permanent mount, mag mount, trunk lip, or anything like that. Does anyone know if the SpectrumForce Mini Window Antenna UHF/800 will handle the 4w output power for transmitting? Thanks in advance!
  #27 (permalink)
Old 06-17-2017, 6:54 AM
eaf1956's Avatar
Originally Posted by n7vdr View Post
$219.99 with programing cable, software free shipping here.
Tytera TYT MD-9600 DMR Digital Mobile Radio
The price jumped to $339.99
BCD536HP (2)
  #28 (permalink)
Old 06-17-2017, 5:09 PM
jonwienke's Avatar
Because it's now dual-band.
  #29 (permalink)
Old 06-17-2017, 5:27 PM
Is it? The "Pre-Order" page still only allows one to select VHF -or- UHF.
Bill
  #30 (permalink)
Old 06-17-2017, 6:00 PM
jonwienke's Avatar
It hasn't been updated yet.
  #31 (permalink)
Old 07-17-2017, 10:43 AM
ARRIVED !!!!
Unboxing in USA on the NEW TYT MD-9600 Dual Band 144/430 MHz Mobile DMR
https://www.youtube.com/watch?v=yauK1AVP5Ag
330 dollars (287 euro ? ) …no much high pice ?
73 de IW2BSF - Rudy
  #32 (permalink)
Old 07-25-2017, 11:59 PM
The TYT MD-9600 is in fact a Dual Band Radio. From the Buy Two Way Radios - Lowest 2 Way Radio Prices Anywhere! website:
"The MD-9600 supports analog and digital modes so you can enjoy the best of both. It provides dual band support, operating on both 400-480MHz UHF frequencies and 136-174MHz VHF at up to 50 watts VHF and 45 watts UHF, using Time-Division Multiple-Access (TDMA) digital technology. This digital mobile radio is also compatible with Motorola TRBO and DMR Tier II."
1000 Channels
• 136-174MHz VHF Frequencies
• 400-480MHz UHF Frequencies
• Repeater Capable
• AMBE+2™ Digital Vocoder
• Encryption (Digital Mode Only)
• Private Call/Group Call/All Call
• 45W/25W Output Power
  #33 (permalink)
Old 07-26-2017, 5:19 AM
interesting if is 340 dollars and if is the SAME FW of the TYT MD-2017 and support the WW database of CALLSIGNS ham-radio in the display ....
  #34 (permalink)
Old 07-26-2017, 3:12 PM
mfn002's Avatar
From the images of the radio I've seen, it seems to have an entirely different format than the 2017. I was kinda shocked that it only had the capacity for 1000 channels/contacts. In other words, except for it being a dual-band unit, it is no better than a Motorola XPR4550 or 5550. I was expecting it to be a mobile version of the 2017, but that doesn't seem to be the case. The only similarity between it and the 2017 seems to be the dual-band feature.
Michael
BCD436HP*BCD536HP*TRX-2*XPR5550*XPR7550*UNICATION G4
SHSU '13
  #35 (permalink)
Old 07-28-2017, 6:17 AM
mfn002 you is shure that the internal Fw an Coduplug is different between MD-9600 mobile and the handy MD-2017 ?
  #36 (permalink)
Old 07-29-2017, 3:34 PM
mfn002's Avatar
I'm not too sure, but going by the difference in the channel capacity specifications between the two I suspect they are. I wouldn't try programming in a 3,000-contact codeplug into a radio with capacity for only 1,000 contacts.
Michael
SHSU '13
  #37 (permalink)
Old 07-29-2017, 3:44 PM
jonwienke's Avatar
1000 channels != 1000 contacts.
  #38 (permalink)
Old 07-29-2017, 3:58 PM
eaf1956's Avatar
Nope price increased yet again, its like $359
BCD536HP (2)
  #39 (permalink)
Old 07-29-2017, 4:22 PM
[Deleted]
  #40 (permalink)
Old 07-30-2017, 1:56 PM
Mototola have no public config software, no firmware updates, no support nothing.
So why should I buy it when I got the same from the Chinese but with an free config software.
Tags
dmr, md-9600
